swbf2cheater
- Aug 14, 2009
gonna look pretty terrible when its docked to an e9 with anything but black mat type color
from now and anf only because of you I am gonna add an spolier to my jokes
"Spoiler: The following comment is a joke"
seriously What is wrong with you?
also: its a stupid and unnecessary effect
much better imo. the thing i keep disliking the most is that angled edge. why not just flat surface? sorry if u dont get what i mean, not native english here.
How horrid. It had potential in the first phase, now it just looks cheap and hokey. Overpriced to begin with and now this. No way. Maybe for $100...maybe.
Because presumably they're using the same side frame and back plate as E7, but since this has line out, digital out, screen and card reader, it needs more space for components inside. Making the whole thing thicker for a flat top panel means they can't use the E7 frame, also a raised center and rounded slope actually fits into tighter pockets better than a thick, flat box. Without an outer case (plastic, neoprene, rubber, etc) a flat thick box would be prone to getting scratches on the edges from tight pants pockets, not to mention the case itself would make it even thicker. Personally though only the IPT4 and S9 have been really, really comfortable in my pockets anyway, and I'm not planning to sell these because of the Fiio. I'm planning to use the X3 more as a transportable, bedside and back-up (for when my main rig's CDP fails) player with a Toucan, so I could go either wa, although I am slanting towards a flat top panel.
I don't understand what's overpriced about it. HM602 looks like a huge brick game but I was more deterred by the size than by the looks.
@feiao,
Are all those colors available, or will you decide which one/s to make?
I've only just discovered this thread, and with 101 pages there's too much to go through.
So can someone please quickly summarise, why would I buy this player over, say, a Cowon J3?
read the OP, that should give you pretty much all the info there is about this player.
Those are some mock-ups that I made, not related with FiiO's plans whatsoever.
Sorry, but the OP doesn't help me at all! The only thing I can see which is unique is the 'coaxial digital output'. I have no idea what that is, or why I would want one!
The Cowon J3 has fantastic audio quality. It's small and light, easy to use, expandable memory and 50+ hours battery life. This Fiio player appears to have:
1. Poorer controls
2. Much, much worse battery life
3. Worse screen
4. Bigger and bulkier
So I repeat my question, why would I buy this player? Is it this digital output that makes it so appealing?
Dont buy one then...
1. Poorer controls
3. Worse screen
