sander99
Yes I understand. I just wanted to give some more context to my other post in which I state that an additional set of drivers by itself will not be perceived as a different channel, I mean will not be perceived as sound coming from a different direction. So using different drivers to work on different frequency bands can be usefull, but it does not mean it would be usefull to also make another "division of work" by adding extra sets of drivers for other channels (for 5.1 etc.).Surely, one driver can be used.
Yet, there are limitations of resonances, cross-couplings, etc.
One membrane can hardly practically vibrate perfectly as needed to reproduce music in 3-decade range of 20 Hz to 20 kHz.
Then a lot of efforts is involved in DDs to make them work better, as mentioned - very strong field, multiple coils, compensation...
To me an array of small drivers each working in a well-defined limited range of 2-3 octaves is a more flexible solution.
What I really mean I gues is: If you think 4 or 5 drivers per ear make a good optimal choice for covering the audio spectrum with good resolution and sufficient sound pressure levels to listen to stereo recordings, then I say that same design is equally good for multichannel (using binaural signals, and multichannel over iems or headphones without binaural signals is meaningless).
