SilentNote
From my understanding, the diffuse field curve is the most neutral / flat. As in if you re-record what is heard at your eardrum, and played it back through the earpiece, and repeat it several times, there should not be too much difference.
Flat signal in, flat signal out.
The harman listener target curve is developed for a different reason - the intended reproduction of music. When a recording studio records music, they “target” the reproduction through a quality hi-fi system in a listening room. Note that this room is not a recording studio and adds “color” to the sound through its walls and ceiling.
The Harman listener target curve attempts to recreate this home listening condition in the IEM. Thus fulfilling the recording studio’s intended playback scenario - making it sound “best”.
Why isn’t flat signal the “best”? Because the recording studio did not record the music intending them to be listened in recording studios, but home theater systems.
Some interesting personal observation: music such as theatrical plays, recorded in the audience perspective (binaural), sound incredibly transparent (even soundstage) with flat iems like the ER4SR. However label recordings always sound better with a colored IEM.
The conclusion is that both target curves are excellent at their intended purpose. For monitoring of microphone recordings? Diffuse field curve flat. For simulating reproduction of home hi-fi? Harman listener target curve.
On other question about human ear sensitivity, our ears most likely evolved to listen to rustling leaves and crackling branches of predators. To miss that is a death sentence. These are both sounds higher than the typical vocal range.
As IEMs bypass the outer half of our ear’s natural amplification system, a good IEM needs to simulate that natural amplification. This tends to be a peak at 2.6-2.8kHz and a roll off at higher frequencies. i.e. the diffuse field curve.
Thus the next time you are auditioning a colored IEM, remember that you are really buying a listening room and a pinna.
