Dec 2, 2018 at 5:19 PM Post #11,176 of 19,072
1. I'm not sure how it works in universities in your country but in England you're not allowed to teach the science of sound/music engineering unless you actually know the science of sound/music engineering! There was almost constant monitoring of lectures and assessment of lecturers' knowledge, both internally within the university and by independent external experts. Even a lecturer is expected to have greater than degree level knowledge when teaching degree level and a senior lecturer is expected to have greater knowledge still.
That doesn't answer my question about the extent of undergrad and grad science and engineering courses you took or degrees you hold, nor whether you've published peer-reviewed research in these areas. No shame in being self-taught, but I'm trying to get an understanding of your background, since you present yourself as a properly-educated expert in these areas. Experts in particular areas of *science* usually hold science PhDs and have published peer-reviewed research in those areas. Do you at least have BS or higher degrees in science or engineering? Note that an engineering degree in the US will generally involve a lot of courses in math, physics, chemistry, and specific engineering topics (which usually involve considerable higher math), and 'sound engineering' as related to recording and producing music isn't recognized as a field of engineering in that sense, but viewed rather as a technology degree. Typical fields of engineering are aerospace, biomedical, chemical, civil, electrical, environmental, materials, mechanical, and nuclear, e.g., https://engineering.mit.edu/departments/ and https://engineering.uic.edu/departments/
I'm not an expert in any aspect of audio or electronics, but I have enough relevant science and engineering background to engage in discussions about measurements, test methodology, how science works, limits of theory, etc., which are the main topics on which there are disagreements.
To illustrate, I don't have any knowledge of how DAC filters work, but if different filter design choices result in different DAC outputs, it's evident that we can't eliminate the possibility of some DACs sounding different to some people simply based on the (invalid) assumption that all DACs convert digital to analog in exactly the same way.
Dec 2, 2018 at 6:34 PM Post #11,177 of 19,072
I'm really not a fan of this persistent appeal to authority. Head-fi is a public forum for amateur audiophiles, not AES or some ethic comity deciding if they will allow our listening experiments. the data presented will come with a given degree of confidence based on how it was obtained(sample size, well documented and controlled experiment, etc). who presents the data shouldn't be the main reason to agree with something. I don't believe in climate change because the guys saying it's real have white coats and PHDs. I believe it's real because of the overwhelming amount of data pointing in the same direction.
Dec 2, 2018 at 7:00 PM Post #11,178 of 19,072
Yep...to my way of thinking, arguments from authority are among the weakest and most arrogant of approaches to a constructive, civilized discussion...whether one is truly an expert or not!
That said...angry arguments from authority are, without a doubt, much more entertaining :wink:
(it doesn't take much to amuse us simpletons!) :ksc75smile:
Dec 2, 2018 at 7:01 PM Post #11,179 of 19,072
I agree. If someone has say a PhD in cognitive neuroscience, specializing in auditory perception, I'm gonna give their comments more weight than some random person in the forum. But conversely, if someone is going to present themselves as an authority on the science, as gregorio and his fans present him, IMO they need to back up that claim to being an authority with info on that person's background in the relevant areas. In the case of gregorio, I'm starting to wonder if he has any science or engineering degrees at all. If not, that's fine, but then everyone needs to drop the argument from authority stuff wrt gregario.
Dec 2, 2018 at 7:03 PM Post #11,180 of 19,072
Try the tone generators. It just makes it easier for the higher notes.
It appears that your ability to detect pitch starts around 40Hz. A non musician might start around 50Hz. As you say, it is much harder to detect pitch in very high frequencies. Yeah. That was basically what I was saying. You just can discern a couple of notes lower on the scale than non-musicians.
Again, I'm not saying that people can't hear differences between tones at the outer octaves. I'm saying they can't discern them as musical notes. If you played "Mary Had a Little Lamb" between 10kHz and 20kHz, you would hear a pattern of changes, but not a tune.
To be honest, this digression is kind of pointless. I just answered that guy's question about where I was getting this from and I googled him up a quick cite. If he wants to chase it down further, he can feel free to do that. It isn't worth arguing over.
I think it's pretty rude to be honest. But I've come to expect that. Desperation isn't pretty. He's only embarrassing himself. I'm moving on.
Dec 2, 2018 at 7:11 PM Post #11,181 of 19,072
I know many people with degrees who are experts in their domain.
I know many people with degrees who haven’t a clue in their domain
I know many people without degrees who are expert in their domain
I know many people without degrees who haven’t a clue in their domain.
Bottom line, not sure that a piece of paper is a indicative of domain knowledge. Personally, I find work history/experience to be a more accurate indicator.
Oh, and this is the internet and I’m Batman...
Dec 2, 2018 at 7:17 PM Post #11,182 of 19,072
Okay, so you are arguing by authority by citing to Einstein as to why one should not argue by authority. :deadhorse::ksc75smile::beerchug:
That's awesome!:L3000:
Dec 2, 2018 at 7:19 PM Post #11,183 of 19,072
Didn't you make fun of an appeal to ignorance argument by posting a picture of J T Gumby from Monty Python?
Wow! I really like your car!
I'm not ashamed to admit that Gregorio knows a lot more than I do about the subject of sound reproduction. I defer to his experience, not because of his resume, but because he brings a ton of relevant facts to the table. He also clearly is more interested in having the truth prevail than he is in bolstering his own ego by using any argumentative technique to "win" the debate. Other people could learn from his example.
Dec 2, 2018 at 7:27 PM Post #11,184 of 19,072
I know many people with degrees who are experts in their domain. I know many people with degrees who haven’t a clue in their domain
I know many people without degrees who are expert in their domain. I know many people without degrees who haven’t a clue in their domain.
So...which is it?
Are you The Hornet or Batman?
Okay, so you arguing by authority by citing to Einstein as to why one should not argue by authority. :deadhorse::ksc75smile::beerchug:
Yes...irony everywhere. :wink:
One of the smartest people the earth has ever seen encourages us to include people in the discussion by offering explanations that they can understand rather than tell them how they're incapable of understanding the fundamentals
TBH...the levels of assumptions/hubris/keeping score/etc. that sometimes occur in this forum can be a tad much. Which, in the short run, detracts from knowledge exchange and ultimately from forum readership/growth/etc.
Dec 2, 2018 at 7:31 PM Post #11,185 of 19,072
So...which is it?
One of the smartest people the earth has ever seen encourages us to include people in the discussion by offering explanations that they can understand rather than tell them how their incapable of understanding the fundamentals
I lead a complicated life. Anyone know how to get a jet powered car with machine guns and rocket launchers through the DMV registration and inspection process? Asking for a friend.
Dec 2, 2018 at 7:45 PM Post #11,186 of 19,072
I know a guy who leaps tall buildings with a single bound. I'll ask him if he knows.
Dec 2, 2018 at 9:49 PM Post #11,187 of 19,072
I've been saying this throughout this protracted discussion. However hearing and perception aren't the same thing. We can feel ultrasonics as sound pressure if the volume level is high enough. In fact, at a high enough amplitude, sound we can't hear could possibly kill us. We would certainly perceive that! But that doesn't mean that ultrasonic frequencies are a factor in the fidelity of recorded music. It's been proven repeatedly that ultrasonics make no impact on perceived sound fidelity. You can prove that for yourself by just doing a blind comparison test of an SACD compared to the exact same recording and mastering bounced down to 16/44.1. I've done that myself and I couldn't hear any difference at all. The two were identical sounding.
Ultrasonic frequencies couldn't be heard with bone conduction or hearing aids either. But you could certainly perceive a good headache if you turn the volume up high enough. Personally, I don't think semantic arguments are a good way to understand how things work. But they are very good ways to obfuscate and derail conversations. People love to throw them in though because they think it makes them sound clever.
I wonder why KeithEmo got the question I brought up and you didn't. I have a feeling that you didn't even bother to click the links I posted.
Here's the first line of an abstract I linked to:
Ultrasound can be perceived by bone-conduction. The cochlear basal turn is involved in processing bone-conducted ultrasound (BCU) information.
And here's a quote from the other study I linked to:
The device was designed to give out a sound pressure level of 85dB for 40 kHz and 60dB for 35 kHz and 45 kHz at around 1meter in front of the sound source.
Your reply doesn't sound like you've actually read any of this.
Also, my post was in response to gregorio's question:
where's your significant evidence for 20kHz not being an upper limit for human hearing?
So I don't know why you feel the need to pontificate about "ultrasonics' impact on perceived sound fidelity", which had nothing to do with the context of my post.
As for your final remark, I think it's condescending and uncalled for. All the more, if you didn't make the effort to understand the context of my post and consider the evidence provided.
Dec 2, 2018 at 10:41 PM Post #11,188 of 19,072
I see what the problem is..... you seem to have misunderstood a few of the details.
This was a test to determine whether the test subjects could tell the difference whether the audio signal was passed through "a CD quality A/D/A loop" or not.
When you are testing whether participants can tell the difference between equal quantities of two different things the expected result due to random chance is 50%.
Therefore, a "statistically significant result" is a result significantly above 50% (how far it has to be from 50% to be significant depends on various things like the number of trials).
And, as it turns out, with the particular number of trials and paricipants involved, 70% correct is far enough above the 50% predicted by random chance to be "statistically significant".
(As you said, those results would be expected due to chance - sooner or later - but three times out of that small number of trials is somewhat outside our usual expectations.)
Now, since the overall number of trials wasn't very large, this variation itself isn't "VERY significant".
It is neither "expected" nor "unexpected"... but the odds of its occurring with that small number of test runs is quite low.
A statistician could tell you how far 80% deviates from the expected random result of 50%, and what the odds are of that deviation occurring in a certain number of tests.
As I said, it's not impossible that this could happen by random chance, but the odds are low enough to make it "interesting" or "suggestive".
And it's certainly easy enough to confirm whether it's significant or not by doing a few more test runs with those subjects.
That result is exactly equivalent to the situation if, instead of listening for differences, those subjects were flipping coins.
If you were throwing coins, and two subjects threw seven heads out of ten, and one threw eight out of ten, out of only 100 total trials, you wouldn't consider it to PROVE anything...
However, since it is a low-probability result, it would suggest that another level of trials would be worthwhile - to confirm the results one way or the other.
You are applying circular logic.
Most current studio recordings don't contain much musical information above 20 kHz.
The reason for that is that most studio microphones have little response above 20 kHz.
(And most recording engineers don't expend any effort trying to record them or preserve them during the mix.)
And the reason for that is that information above 20 Khz isn't considered to be useful because it is assumed that nobody can hear above 20 kHz.
Therefore, since the information is largely absent, and no attempt is made to preserve it when it is present, nobody is going to hear it.
HOWEVER, this doesn't prove either way whether people would or would not hear content above 20 kHz IF IT WAS THERE.
(Again, I'm not SPECIFICALLY claiming that it's audible or not... just that we haven't actually tested the possibility... we simply "go with the assumption".)
Generally microphones are chosen to "sound good" - which includes being able to pick up whatever frequencies contribute to that result.
I have little doubt that, if tests were to find that "cymbals sound better when recorded with microphones whose response extends to 30 kHz"....
We would soon see studio microphones, designed specifically for cymbals, whose response extends to 30 kHz... and sold specifically for recording cymbals.
(And considering that cymbals are often recorded by an overhead microphone located within a few feet.... it shouldn't be especially difficult to record them.)
I've personally made very few recordings...
And I've certainly never recorded a drum kit using a microphone whose response extends to 30 kHz "just to see if anyone thinks it sounds better"...
Have you actually tried it?
(Or are you just assuming that it won't sound any different.)
1. What do you mean nobody said anything about far above 100%, YOU DID! You stated "two or three of the participants were in fact able to tell which was whcih with far above statistically significant results." - Statistical probability distribution predicts and expects one or more 100% results from pure chance alone. So if you're stating that participants could tell which was which FAR ABOVE statistical probability then you are stating FAR ABOVE 100%!
2. No, that is untrue, it IS expected!
2a. An 8/10 score out of so many trials IS NOT an anomalous result, it is entirely predicted and expected! It's ironical in the extreme then that you state "if you understand statistics", as clearly you don't, or maybe you do and it's just another of the countless "inadvertent" mistakes?
2b. No, they were not "lucky that day" those results are ENTIRELY EXPECTED sooner or later.
3. The study does not provide absolute proof that hearing a difference is impossible, but it does provide compelling evidence. However, it provides no evidence whatsoever that hearing those differences is possible! BUT, even if we accept your misrepresentation of luck and what's possibile, STILL YOU ARE ADMITTING that your statement "two or three participants were in fact able to tell which is which" WAS FALSE, as now you're saying it's only a possibility they could tell which was which and NOT A FACT!! Again, when is enough, enough??
4. Just to be clear then, you are NOT talking about the reproduction of commercial music recordings or the hearing/listening to those recordings.
4a. Personally, I don't deal with testing bats' communication abilities and neither does this thread!
5. Yep, they are in general all made using microphones. Are you going to propose another recording scenario which doesn't exist?
5b. Nope, it has nothing to do with that, which you would know if you'd ever taken even an introductory course in microphone use. But you haven't and you clearly have no idea what influences music mic choice, instead you just make statements of fact and "suggestions" about something you have "no idea" of and argue with those who are actually professional mic users. That's ridiculous and even more ridiculous that you don't seem to realise it's ridiculous and just keep doing it! So yet again, when is enough, enough???
G
2. So no education at all in the subject and no more than a hobbyist's knowledge or experience. More or less what I presumed.
3. Me too, IMO that's where music/sound really gets interesting! Unfortunately though, instead of discussing the real interesting stuff, I'm bogged down refuting misrepresentations of basic technical stuff that has no impact on perception beyond the phycology of marketing snake oil.
4. I obviously can't dispute what you think you know but your posts demonstrate that you are missing a number of absolutely fundamental basics of the science behind audio. For example, in the Rob Watts thread our discourse between about post #350 and #376 demonstrated that you didn't know what the 0's and 1's in digital audio actually represent or even how measurements are represented in binary. Without that basic knowledge we're stuck, we can't rationally discuss digital audio and the proofs which underpin it because it's all based on binary. So, you're not going to be able to understand those proofs or have any reason to believe them and therefore we're reduced to non-rational discussions of digital audio. Arguments about opinions, beliefs and perspectives which are in fact irrelevant but to you they're the only things that are relevant because you do not know and cannot appreciate the actual facts/science. And then, you quote dunning-kruger and other cognitive errors to others, apparently completely unaware of the irony.
G
Dec 2, 2018 at 11:06 PM Post #11,189 of 19,072
That sounds right to me, and pretty interesting. My observations were based on personal sensory experience and having thought about it in the past and a little reading and what other people told me, which we both know can be pretty flawed, so it's interesting to see us on the same page. I did learn how much the introduction of audible harmonics introduces so many new variables into the situation, even more than I had previously appreciated, both at the low end and the high end. This is easily enough discerned in comparing sine wave tones with piano notes--it's a qualitatively different task to discern the pitches for the piano because of the rich harmonics. You get extra hints from harmonics for some ranges of pitches (I'd say 41 to 52 hz at least) and harmonics muddling things up for other ranges of pitches (starting up around 4 khz or somewhere around there, and from 27 hz to 40 hz). FWIW. For me this is good stuff--music and sound and perception!
