analogsurviver
- Jul 2, 2012
The way you fix a record pressed off center is to take a rat tailed file and open up the hole on the side you need to shift towards. I've never seen it on LPs, but there are occasionally 78s that need filing.
It is not until one goes to linear tracking arm ( and vacuum hold down turntable ... ) that the eccentricity of PRACTICALLY ALL LP records becomes glaringly visually appearent ... - but, you can hear the deletrious effect of off- center pressed record exactly as well with a more common pivoted tonearm.
Here a video by my acquaintance - made practically to my request. I wanted him to showcase the tracking and tracing abilities of Jico SAS stylus for the vintage Technics EPC-P22 ( or EPC P-202 ; same thing ) P-Mount phono cartridge - at the innermost grooves of a LP, where the performance is at the lowest. The close shots of the short arm ( effective lengrth 115 mm ) clearly showcase eccentricity of the record; and I wanted him to present it as it is, with all the good - and few bad.
DISCLAIMER : The following video(s) from YT are only information regarding the ultimately achievable quality of reproduction from analogue records - up to the best SQ allowed by the YT at the time of the original upload.
You can "scan/sample" the entire contents of his YT channel - with all the limitations of the YT, it is still possible to discern the general type of sound a particular analogue record playback rig produces.
I do not have anything comparable to his video equipment ( and video skills ) - but what I do have is a plethora of MUCH improved Technics linear tracking decks ... - with solutions that all help an even better - audibly better - standard of reproduction from analogue records.
