This is a pointless argument... your theoretical conditions do NOT encompass all the permutations commonly encountered in the real world.
I've owned plenty of analog preamps which had 20+ dB of "excess gain"... and so were able to deliver a fair approximation of a square wave with high-level inputs.
Also note that, while I don't know the conditions others were assuming, I never said that we should assume "the same amount of gain".
In real life, what we frequently encounter is that, when someone has an underpowered amplifier, they turn it up until it clips.
Then, when it still fails to play loudly enough, they turn it up FURTHER.
The result is a solidly clipped signal which is also loudness compressed (the peak level was limited by the amp but, by continuing to boost the gain, they're also significantly raised the average level).
As a result, the signal has both a much higher than normal average level, and, thanks to the clipping, a disproportionate amount of high frequency energy.
If you talk to anyone who has processed or repaired a significant number of damaged speaker...
You will find that damaged tweeters are disproportionately common...
You will also find that damaged tweeters are disproportionately common among users who have low-powered amplifiers.
I leave it to you to figure out how much of this is due to the facts I've described...
And how much is simply due to the possibility that the sort of people who buy underpowered amplifiers are also the sort who are more prone to turning them all the way up, ignoring obvious signs of distress with their speakers, and waiting for smoke to appear.
I should also note, however, that I can easily produce a very similar effect by deliberately causing excessive clipping on a digital audio editor, or by using "a brick wall limiter".
(That effect being to raise the average level, sometimes by as much as eight or ten TIMES, while the peak level remains the same.)
In fact, the theoretical ultimate result of applying massive amounts of gain, combined with hard limiting, would be to turn music into a series of full amplitude sine waves at various frequencies.... and I haven't seen many tweeters that could tolerate a 100 watt 5 kHz sine wave for very long.
(And, no, I wouldn't want to be in the room with one if it could.)
If you really require a "graphic example" of this...
Take any music file you like (choose one that is normalized so the peaks are at about -1 dB but are NOT clipped).
Analyze the average power level.
Now, boost the level of the entire file by 20 dB (ignoring any clipping that may occur).
Analyze the average power level again.
You will obviously find that the average power level is now significantly higher.
(And, if there is a lot of clipping, you will find that the average power level at higher frequencies is increased disproportionately.)
Show me real data. Ive looked,it’s just not there. What you’re looking for is hard evidence that a clipping amp blows a tweeter but a non clipping amp at the same gain does not. POST if you find it.
Clearly you have not actually tried this. It takes 40+ dB if gain past clipping to eve approximate a pseudo-square wave. Not possible in the real world.
Quite incorrect. A 100W amp driven past clipping will output more than 100W rms. Look at the first graph which shows exactly that.
But that mid range and tweeter energy is insignificant compared to the music content there. Look at the graph that shows the spectrum change with clipping. These are actual measurements.
You’re clinging to the myth! It’s like you never read my post or looked at the pictures! All your objections have already been addressed.
With 40dB of gain past clipping you still don’t get square waves. You might just try it instead of posting more errors.
If you drive your 100W amp 10dB past clipping you get more than 100W! But not more than the unclipped amp at the same gain. Look st the first graph again.
Now, I’ve post a graphic proof of what I’m saying. You’ve posted nothing but opinion. If you like to post some actual proof, I’d be happy to look at it.
