I'm sorry.... which fallacy was that?
The one about how, quite often, things that are "widely believed to be true" are later found to be wrong?
I've been around to hear a whole long list of things that "were obviously true"......
Until, after a little more research, someone found out that they weren't true after all.
I though it was obvious that I was being sarcastic.... of course it was predictable.
When Sony's new product was the CD, their tests managed to show that CDs were clearly superior to previous products, but were "the pinnacle of audio technology".
Then, when their new product was the SACD, their new tests showed that IT was clearly superior, and was the pinnacle of technological achievement.
Yet, for some reason, you seem to choose to believe their first test results but not their later ones.
I'm personally inclined to believe that their scientists were smart enough to figure out a test procedure to show that, whatever their new product was, it was worth buying.
And, yes, every company who sells high-res content, and every record company who gets another license fee when a re-master of any sort is sold, has a vested interest in convincing you that high-res files are better.
And, yes, every company who sells CDs, and everyone who already owns a large collection of CDs, is biased to prove that their CDs are plenty good enough (otherwise they wasted a bunch of money).
And, yes, every scientist on the entire planet is biased to run "a significant test" that "produces interesting results" - so he can get his paper published.
Of course no commercial venture or organization is going to specify audiophile equipment...
They're going to specify the cheapest equipment that will satisfy most of their customers...
(But that sounds an awful lot like what I said.)
I can't speak for "most things".....
But, more specifically, when you're testing something, your test equipment must be "better" than what you're testing... so that it doesn't obscure or just plain miss the data you're looking for.
So, for example, if you're trying to compare the distortion on two amplifiers, both of which have a THD less than 0.1%, the equipment you use for your test must have much lower than 0.1% THD to avoid obscuring the results.
Likewise, if you're hoping to determine what amount of ringing is audible on a DAC, you must start with test equipment that has less ringing than the DACs you're testing.
As for jitter....
I consider actually knowing what I'm talking about to be quite relevant.....
(I was simply pointing out that, if the BBC says jitter levels below 45 nS are inaudible, then their results are either incomplete or incorrect.... most likely they simply tested one particular type at one particular frequency.)
Nice try but all you've really done is proven my point!
1. Oh good, let's start by using a tried and trusted old audiophile marketing fallacy! The truth is of course that we don't need to know everything, just a great deal about a few things, the properties of an electric current for example and in digital audio, just amplitude and time. An inconvenient truth I know, hence why audiophile marketing fallacies are so commonly used and recycled!
2. No, I wouldn't find that, I can understand (and have already explained) why you would want to make that insinuation though!
3. What's "oddly" about that? It's the exact opposite of "oddly"!! It is in fact PRECISELY in line with what I stated, baring in mind that Sony is also an audiophile manufacturer. Your statement should actually read: "
Then, 100% predictably, nearly two decades later they were saying that audiophiles needed to move on to SACD...."
4. No serious commercial studio or organisation is "going to specify audiophile equipment", because it's overpriced nonsense that's typically inferior to even just decent quality pro-audio equipment! However, the BBC does specify some very high-end pro-audio equipment and it definitely does consider the MOST discerning of listeners and has done for decades.
5. No, the ADC's quality of conversion is largely irrelevant for most things. Whatever weaknesses/inaccuracies the ADC has will be the same on both recordings and therefore NOT a difference.
6. True but irrelevant, another classic old audiophile marketing tactic, thanks for playing the game!
G
G
G
