So your "elephant" is around 1% of an already minuscule segment if the music available? Sounds more like an ant.
Pure DSD is about as dead as binaural. There's really no point if what you want to listen to is not available on your favorite pet format, is there? It's the hires problem only about 100X worse.
"About" equals "almost" - and almost NEVER caught a hare.
That's why, being - not only ignored but suppressed by, whenever and wherever given a chance - mainstream recording engineers like
@gregorio, we had no choice but to start creating our own binaural content. I started with a portable cassette recorder - and, after discovering what a wonderful machine Technics RS-AZ 7 is, although not portable, used that in stock form for a very short while. Within a year, I had it modified and running in its purest mode possible - with noise reduction being taken care of with Nakamichi High Com II. And I would not even consider using the Naka in its stock form - I had to purge the two units ( one required for recording, one for playback if monitoring while recording is necessary ) of all the Kinderkrankheiten Nakamichi has - clearly - re-wrote and re-used and therefore inherited directly from the Telefunken High Com unit , obviously without any critical assesment by either measurements or AB listening to the source and recording. Those differences being audibly so large that it NEVER occured to me to do a blind test - and if somebody is willing to try that one with High Com II, he or she will have to bring two stock Naka High Com II units ( preferably restored, BUT ONLY TO STOCK CONDITION ) - in a live, in front of audience, double/triple/x..le blind ABX. Making an ABX box that can accomodate switching of one analogue tape recorder and two pairs of two noise reduction machines would have also to be designed - no trivial task, but in principle doable.
Of course, Naka High Com II can also be paired with R2R , not only cassette recorder - if somebody *feels* cassete is not good enough. On a HIGH quality headphone setup, - let's say Stax Lambda Pro with mandatory ED-1 Monitor diffuse field equalizer + "some quality amp" - because it is relatively widespread and known to be specifically good with binaural recordings. And, if somebody would be foolish enough to claim that a 44.1/16 PCM is better than either the cassette or R2R, he/she *might* meet the ultimate analogue nemesis of the RBCD PCM - (S)VHS ( or beta) VIDEO recorder used exclusively in audio mode. The only trouble is that today really good (S)VHS tapes for audio are - unfortunately - history; so, in commercial sense, this point is moot. But such a comparison could still be arranged - I do have a few still sealed premium quality tapes.
And , guess what ? Many musicians themselves, after being treated with a lifelong diet of multimiking only, will light up as little suns - after finally being able to hear themselves WITHOUT the inevitable "editorial comment" of multimiking and subsequent subjective interventions during mixing/mastering by the likes of
@gregorio. The same - or even more - that goes for the concert goers; after all, all that they can ever experience live is certainly closer to binaural than to any version of multimiking - as per default, the skill and experience of the recording engineer playing here - at best - next to no role. The less intervention on the part of the multimiking engineer, usually the better - in most, but not all cases.
But, not all musicians/listeners prefer 2 channel stereo/binaural to multimiking - that's why I always tell the prospective customer/musician what I do and what he/she can - or can not - expect and get from me. Thus I will always allow for an informed decision.
Since with 2 channels recorded, without the possibility to do after the fact ANYTHING but splicing the various takes of same song/composition recorded under exactly the same conditions/mic placement ( valid for both direct to tape and direct to DSD, if you will call it that way ), there lies the knowledge/skills/experience a multimiking recording engineer has never been required to do. Getting as good balance and separation as possible while scrupolously maintaining spatial coherence is no trivial matter - and does require more time in preparation than with multimiking, where "we can fix everything in the mix" notion usually prevails.
The 2 channel only recording "mix", either stereo or binaural, has to be get right - there and then, BEFORE the first note that will eventually land on a released recording can be played.
Fast forward to binaural recorded in native DSD. Yes, it is rare, it is a niche within an already small niche - but it DOES exist and DOES fullfill the needs and expectations of at least a small portion of listeners. And, it is being steadily increased in numbers of the binaural recordings available. More and more native DSD recordings available on
https://www.nativedsd.com/ feature, besides stereo and multichannel ( usually 5.1 ) also binaural version. Recording machines ( usually Merging Horus/Hapi ) feature 8 channels of up to DSD256 - and, with six channels being required for the surround 5.1 ( from which then stereo is usually derived ), two channels remain free - so WHY waste them, and not put to a good effect - the BINAURAL ? The customer then decides which version of the recording of the same music he/she will buy - based on preferences, listening habits and, last but not least, equipment available. There are also convinient "bundles" and, in some cases, discounts available to those who have bought in the past say stereo version, but during time decided to add surround and/or binaural version of the same music - it will not be "full" price as to the first time customer for a particular album.
The cruelest price range for the playback equipment is with surround DSD 5.1 ; if one satisfies him/herself with DSD ( all the way to native DSD256 5.1 available ) converted to PCM ( normally 192/24, 5.1, but usually user selectable all the way down to 44.1/16 ), some 300 EUR ( price of a new "DAC/Soundcard" ) will get you a decent playback. If you want all the way to native reproduction of DSD256 5.1, the price can quickly go to approx 11K .
There ARE MANY choices in DAC that will play 2 channel native DSD , all the way up to DSD256 - starting at around 200 $/euro/pound. All that is required for stereo - or binaural.
