KeithEmo
Member of the Trade: Emotiva
- Aug 13, 2014
In principle, your "test and validation methodology" is very sound... and quite sensible...
However, it only has two flaws, which are quite closely related, and which are to a degree unavoidable.
Conditions change, and your ability to test a particular device under a wide variety of conditions is usually limited.
What if you hear a difference today that you didn't hear yesterday BECAUSE YOU'RE USING EQUIPMENT TODAY THAT YOU DIDN'T HAVE YESTERDAY?
What if you hear differences today ON A RECORDING THAT YOU DIDN'T HAVE YESTERDAY?
And, at the risk of being contentious, I'm only going to accept the claim that "you can't possibly hear something different with a different set of headphones or pair of speakers" if you're prepared to claim that you currently own an "audibly PERFECT" set of either, and so have ruled out the possibility of ever owning a set that will be "better" and so reveal things that your current set have failed to... or if you have a "perfect quality and perfectly comprehensive test file", and so have ruled out the possibility of ever having one that is better, and so requires something additional in the playback signal chain to reproduce it "audibly perfectly". (I've certainly heard differences that seemed obvious on one set of speakers, but totally inaudible on another, or obvious on headphones, but totally inaudible with speakers, or obvious on one piece of music, and not noticeable with another.)
If they can hear it clearly in a controlled test and care about it, that's fine. But that doesn't include inaudible stuff that's a result of sloppy comparison tests or expectation bias. No one can really hear stuff that only exists on paper or in their head, and no one should waste their time caring about meaningless or imaginary stuff.
I don't believe in "improvements in hearing acuity". Your ears hear what they hear and that's it. You can be paying more attention now than you used to, or perhaps you have expectation bias to make you think that straining to hear better actually will make you hear better. But if you do actually hear something you didn't hear before, that just means that your earlier impressions were due to sloppy comparison tests and something got by you. When I get a new piece of equipment I make the effort to do a careful comparison test right away. If it passes the test, I don't worry about it any more. So far, I haven't run across any amp, DAC or player that doesn't pass the test.
