analogsurviver
- Jul 2, 2012
Do you deny that expectation bias is a potential problem in observing difference between electronics? If not, how do you know that what you claim is true?
No, I do not deny the potential effects of expectation bias. That is why try to "employ" as many people not "electronically scientifically affected" - utterly incapable of any expectation bias of whatever origin. They simply say which is the closest to the real thing - end of story.
It is NOT fun to listen to, switching among while recording, to :
1. Mike feed
2. Recorder A
3. Recorder B
I try to get the levels as equal as possible - but not at the cost of having to record at reduced level just to get the same output from a recorder that has higher output for the same nominal level of recording and no output level control. Louder should be better - right ? But if the lower output recorder trounces the louder one - it must be doing something a lot better - wouldn't you agree ?
This has been confirmed by others - clients for my recordings. They only listen to their performances - and will, with a delay ( a CD gets out approx half to one year after the recording ), respond to any changes I made to the equipment. They have mostly absolutely no idea about the technicalities - only the end result counts. It is good it is on CDs only (so far...- due to financial constraints) - any hirez would highlight these differences even further.
