cel4145
The secret ingredient is White Bat Guano. One has to put something in there besides a picture of Ace Ventura on the label.
lol
Probably has to say "Tier 1, Flagship oil" somewhere on the label as well.
Or how about your turntable mechanical parts have to be lubricated with a specific audiophile grade oil? There are already plenty of people being taken by claims regarding expensive lubricants with tools and firearms. I think we should buy some generic lubricant, repackage it in a pretty bottle with the name "audio grade" and on it, mark up the price at least 500%, and tons of fools would buy it. The guy that run's multitool.org did that just for fun for multitool enthusiasts : Uncle Def's Premium Tool Oil: http://forum.multitool.org/index.php?topic=51383.0.
Here is the best part in his description of the product
Be easy enough to convince audiophools that a different labeled bottle was a better grade just because it's a different labeled bottle and the manufacturer says so
All turntables should remain in their boxes.
I have a nasty feeling turntables will keep on spinning into the time the NEXT generation will no longer recognize what CD is and what to do with it ...
I remember a girl then 6, after seeing a vinyl LP for the first time, saying :
What a BIG - CD ....
And for recording, the microphone should ideally have low noise as well, which is not as important for the originally intended application of frequency response measurements. A small capsule generally has a more extended frequency response, but worse SNR.
Oil as dialectric has been used in particularly high voltage application
LOL, [COLOR=0000CD]98.7654321 %[/COLOR].....:atsmile:
Unfortunately, there is LOTS of "fishing in murky waters" regarding oil for lubrication of turntables. As described above.
There is at least one oil that is, regardless being expensive like hell, high tech ( nano balls ) and legit : http://www.vandenhul.com/products/accessories/the-lower-friction-tlf-special-oil-type-i-and-ii
Holy horrors - it is even recommended to improve/prolong the life of bearings of CD players:eek: !
The best turntables no longer use bearings requiring lubrication - one way or another ...
and yet ironically she probably had better hearing than most of the middle aged audiophiles here.
Yes. But you need to be concerned about any friction between the tone arm and the mechanical parts that allow it to pivot relative to the rest of the turntable. Audio grade lubrication can reduce friction and create better soundstage and imaging, right?
I have hundreds and hundreds of laserdiscs. I'm trying to think of a craft project to make out of them.
