So your issue was write speeds. Read speeds are much faster, typically at least 2 or 3 times faster. I have a lot of trouble imagining that DAPs are having any trouble with the read speeds on any Class 10 cards.
How do you know that other micro sd cards add audible noise to the signal? If they don't, then it's not a "plus" to spend all that money on that card. I think this new card is probably just a solution in search of a problem.
I did state what the problem was. Still is - I really must check is this Sony card can write fast enough.
I DO NOT know for sure whether other SD cards add audible noise or not - because I do not own any device using them - yet. But I do know that I do prefer external USB CD burner with its own power supply over the version of the same for mounting in the PC itself - because PC is the last place one can find decent power supply.
Miniaturization took a HEAVY toll on recording equipment - anything in now almost mandatory 1U rack size is simply too small - and forces the use of next best quality components that can be cramped into so small volume. Meant is PRO level gear - now you can imagine what my opinion on a smartphone sized audio might be.
OK, it works . Question is - HOW ? Or better - how much better it could have been if not necessary squeezed in those thin sizes/volumes ...
I am no way pushing for this new Sony card (far more pressing purchases than that on the horizon ) - but although I am no Sony fan, at least not a huge one, they did come up with better than competition solutions in the past - although at cost. And were not challenged for considerable time, if at all.
I hope this new card does have some real purpose and justification for its existence. Sony did push in the past batteries and "memories" all proprietary, which served no other purpose but forcing its customers to remain loyal to Sony if they wanted to use their Sony equipment at all. This luckily changed in the last few years - standard batteries, standard "cards" , etc. If they managed to pack something tangibly better in this new card, it is fine with me - but only if. The price is always a factor - but if the new card is fast enough for my use, it is a WILD BARGAIN compared to Hoodman's - just do the math of capacity/price.
For pure playback, the only real benefit could come from reduced EMI/RFI and of course reduced power consumption - portable devices do not run on batteries, which by now have stabilized more or less in capacity, forever...
Every one has to consider what his/hers requirements are - and whether he/she can afford it. This Sony card is probably OTT for most DAP users, might be beneficial with some gear and might be indespensable with admittedly even less gear. Whether it is worth it, depends on each case by case basis. And if it does provide some real benefit, will spark competitive manufacturers to come up with something similar at lower price or something better at the same price. Which should benefit us all.
I, as everyone else, would like to have my sports bulldozer with low mileage - for free. Yet we all know this will remain in the domain of dreams only. In real world, I will always go for the minimum that will unconditionally support the result required - sometimes it will be a 0.50 $ RCA connector, sometimes it will have to be a $500 SD card - because nothing else would do.
