Heidegger
- Jan 28, 2011
1. you did not mention you had been messing about with gain settings, had you done so I would have mentioned the influence of volume levels which I did once you mentioned the gain settings changes. You witheld vital data. . . . I am not psychic
2. How can I solve a problem without all the required data
1. It's news to you that amps may have gain settings and/or that they may be adjusted by the user? You didn't consider it even as a remote possibility?
2. Well, that's just it. You don't always know whether you have all the required data. You might come to a certain conclusion with the data you do have and totally fail to see that you did not have some crucial bit of data that would change the results. How often are we told about studies that conclude such and such a thing only for the conclusion to be totally reversed a few years later? The scientific method is accurate and rigorous, but if it turns out that one or more of your premises is faulty or that crucial data was missing, then the possibility for error becomes great. Also, seemingly irrefutable statements, even those based on established laws of physics, can be wrong. There was a time when scientists believed that everything in the universe -- everything material at any rate-- was explainable through Newton's laws of motion. Today of course we know that that is not the case. Finally, it behooves everyone to remember that not everything can be measured -- lest hubris infect us.
