castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
Short or long listening doesn't matter if nothing is in place to show when we're wrong.
I would go with subjective preferences. As long as one is honest and open about that to others, and doesn't try and turn it into pseudo-scientific 'facts'.
But I think an even better question is: how much are you prepared to pay extra for something that likely is a perception bias? If science suggest it is 99% likely a perception bias, then my decision usually is based on factors other than perceived differences in sound, such as preferred aesthetics, functionality, durability etc.
Sure, listening for longer periods of time might subjectively enable perception of differences, but does it seem logical for one to enjoy or believe those differences to be real if they would not be immediately apparent when volume-matched ABing with an instantaneous switch (unless you are saying that prolonged listening enables subsequent immediate perceptibility of quick switches)? It seems like an intentional act of maximizing psychological influences and audio memory errors/drift to create a subjective effect out of one's probably measurably inert gear. Otherwise, maybe tweaking around immeasurable things really is the only psychological solution for some individuals' perception inducing hindrances that some others may not perceive at all.
ABX only tells you if you hear a difference between A and B or not. If you do then you still have to decide, subjectively, which one you prefer. And then you can be sure that your subjective preference is guided only by the sound and not anything else.The better question is, do you go with ABX or your subjective preferences at the end of the day?
That's not what he's saying. He says you can't trust your senses if you do uncontrolled comparisons. Doesn't matter if they are long or short.Let's not trust our senses with long term music listening in a relaxed state,
Not knowing which of the two is playing confuses you? I would be worried if it happened to mebut only trust our music listening senses in a confused state while taking blind listening tests?
Actually even then you could just ignore the sound differences and go by the look or sth else. So if you are really serious about it you'd have to do some blind preference test. If you already know, from ABX, that you can distinguish them then I guess it is enough to just play both without knowing which is which and decide which you prefer. But I'm not sure if that's good enough, so don't quote me on thatABX only tells you if you hear a difference between A and B or not. If you do then you still have to decide, subjectively, which one you prefer. And then you can be sure that your subjective preference is guided only by the sound and not anything else.
No evidence = no reason for trust. It's not a social party, but a thread about testing the reality of something.Let's not trust our senses with long term music listening in a relaxed state, but only trust our music listening senses in a confused state while taking blind listening tests?
You can do both, as they are not mutually exclusive.
I would say, you have to check which one does the job wrong.ABX only tells you if you hear a difference between A and B or not. If you do then you still have to decide, subjectively, which one you prefer.
There is no right and wrong with subjective preferences.I would say, you have to check which one does the job wrong.
That's your choice. Doesn't mean it is right for everyone.But i would not buy the worse amp because i prefer its distortion.
That is correct. But you have to admit, that it is an very time consuming and also expensive gamble to see what device does what things objectively wrong to, by accident, match what you prefer subjectively.There is no right and wrong with subjective preferences.
You have that entirely backwards! Either you confuse your music listening sense by allowing your other senses (EG. Sight) to interfere with your music listening sense (Hearing) or you do a blind test which isolates your music listening sense and therefore it cannot be confused by your other senses!Let's not trust our senses with long term music listening in a relaxed state, but only trust our music listening senses in a confused state while taking blind listening tests?
True! Either you are relying on your hearing (in the case of a blind test) or you are relying on your hearing and sight, plus all the cognitive biases knowledge from sight will cause (in the case of a sighted test). Therefore the question is: Do you want to know what your “music listening sense” (hearing) is actually telling you or do you want to know what your biases and non-music listening senses are telling you? If it’s the later that’s up to you, but of course you do not then get to claim that what you experience is due to your “music listening sense”!I guess the point I'm making, you are relying on your senses in either case.
Yep, another audiophile nonsense video completely devoid of facts that are trivially easy to actually test. He goes on about the differences in harmonics between copper and silver but of course it’s trivially easy to objectively measure frequencies/harmonics/“tonal balance” and the claimed differences do not exist. Who would buy products made by a company who apparently don’t even know that it’s possible to measure frequency response? …Another fun video.
What's inside most audio cables? Ah I should just google it... copper. While I'm at this... what is the warmest cable I could get/create?Yep, another audiophile nonsense video completely devoid of facts that are trivially easy to actually test. He goes on about the differences in harmonics between copper and silver but of course it’s trivially easy to objectively measure frequencies/harmonics/“tonal balance” and the claimed differences do not exist. Who would buy products made by a company who apparently don’t even know that it’s possible to measure frequency response? …
G
For maximum warmth, I would rely on https://marlybird.com/blog/cable-knitting-tips/What's inside most audio cables? Ah I should just google it... copper. While I'm at this... what is the warmest cable I could get/create?
Hmm. It could be tin-coated stranded copper with red copper ends crimped into place, but with the cable direction reversed after 50 hours of burn-in.
Resistance wire is going to get you the warmest cable. Some Constantan, or Nichrome maybeWhat's inside most audio cables? Ah I should just google it... copper. While I'm at this... what is the warmest cable I could get/create?
Not knowing which of the two is playing confuses you? I would be worried if it happened to me![]()
