71 dB
I tend to "ignore" this thread because it is pinned always on the top. It doesn't "jump up" as a sign of activity.
There are no standards for consumer (analogue) audio to revise. It’s down to individual manufacturers (and market forces) to decide how much RFI rejection their equipment provides. It would effectively be incompetent to design consumer equipment with so little RFI rejection that its audible performance is affected by the levels of RFI encountered in consumer environments, as competing products are not affected. This isn’t the case with digital audio transfer, where there are bodies which define standards (for example, for USB, Ethernet, etc.) and they do produce revisions. Although these tend to be for extensions or updates to the protocol to allow more functionality or higher transfer rates for instance.Would there be regular standard revisions for consumer audio in regards to RFI rejection ?
In the case of old consumer equipment, from a time when RFI was significantly lower in consumer environments, it may well be more susceptible to modern levels of consumer RFI but equally, as there is no fixed/standard level of consumer RFI, modern levels of consumer RFI may well fall within the rejection tolerance allowed by a particular manufacturer at that time.
G
Indeed. Particularly CDMA phones (Verizon is finally ending this horrible format).Op amps are really fond of singing along a nearby communicating cellphone. Some more than others but they all sing if not massively shielded. It's usually worse with portable products for various but kind of obvious reasons(space, grounding, high sensitivity transducers making all picked up crap louder).
More convenient to wear the tin foil hat that way you cover everything, just make sure it is properly grounded or the hum will get inHMMMM. Are you guys saying I should wrap my opamps in a shield?!
