Jun 9, 2022 at 10:20 PM Post #15,271 of 19,075
And to further indulge my shallow taste for audio related aesthetics (well at least I do find the cable to look rather pretty) and because I never tried this sort of cable myself, I have bought myself a fancy power cable from Amazon.
Nothing really expensive (28 Euro), but still more costly than an average one you can get for 6 bucks or less (and obviously free with the DAC/Amp you have bought.
Let's find out how well this cable "greatly reduces noise and enhances the entire audio system with wider dynamics".
My guess is that it does jack s**t, but oh well, at least it looks nice :)
Nothing wrong with a nice looking cable. :)
What device are you using it with?:gs1000smile:
Jun 10, 2022 at 2:42 AM Post #15,272 of 19,075
This one :)
Jun 22, 2022 at 4:16 PM Post #15,273 of 19,075
Here is an idea:
Since electricity doesn't really travel inside the electric cables, but rather around the cables as an electromagnetic field, how about selling snake-oil air to audiophools?
That is incorrect, electricity does not travel around the cable as an electro magnetic field.
It seems your confusing a few different things together. I assume you're referring to the skin effect with solid core cables. It doesnt work the same way with stranded wire thats bundled together without a dielectric between them.
Yes the electricity does travel inside the cable, but in a solid core cable, most of it travels closer to the surface of the core (skin effect). Anything that carries power has an EMF and it moves with the flow of power. The shielding and dielectric help to contain this field and also to prevent outside emi from interfering with the signal.
Whoever told you that electricity travels around the cable as an emf is the one peddling snake oil.
Jun 22, 2022 at 5:28 PM Post #15,274 of 19,075
I learned that current is the flow of electrons, but that electrons move very slowly, while the energy is "carried" outside the wire very fast(speed of light or something).
Jun 22, 2022 at 5:30 PM Post #15,275 of 19,075
I don't bother arguing with you. I don't care what you believe.
Jun 22, 2022 at 5:36 PM Post #15,276 of 19,075
Depending on if it’s dc or ac/signal.
Jun 22, 2022 at 5:43 PM Post #15,277 of 19,075
I read on a manufacturer's site that electricity flows like water, so I had all the wall jacks in my home moved up at the top of my wall, so the current can flow downhill to my stereo components.
Jun 22, 2022 at 7:52 PM Post #15,279 of 19,075
Jun 22, 2022 at 8:46 PM Post #15,280 of 19,075
If they don't know which one this is in reference to, they have no business commenting on this subject.
Jun 22, 2022 at 9:02 PM Post #15,281 of 19,075
Looks like I responded without much context. Are we talking about skin effect in relation to audio frequency?
Jun 22, 2022 at 9:42 PM Post #15,282 of 19,075
Jun 23, 2022 at 7:55 AM Post #15,283 of 19,075
No, it doesn’t. Electricity (EG. 50Hz mains) has a skin effect depth in copper cable of around 10mm (8.5mm in the case of 60Hz mains) and as consumer electrical cables are significantly less than 10mm (or 8.5mm), the electricity travels equally through the core and surface.
Skin effect depth decreases inversely to frequency, at 1kHz it’s around 1.2mm and at 20kHz it’s around 0.7mm. So, skin effect only potentially becomes an issue (skin effect depth being significantly less than the cable’s cross-sectional radius) when we get into frequencies above about 100kHz or so.
G
Jun 23, 2022 at 9:57 AM Post #15,284 of 19,075
G
So you think this is an absolute regardless of gauge of wire? Does this change with quality of copper (ie ofc, occ), silver plated copper, current, configuration of the cables (ie litz), etc? Or are you referring to only cheap consumer "included in the box" ac cables?
There are alot of variables you're ignoring.
In DC electricity travels uniformly, not in AC.
And yes the skin effect has a greater effect above 100khz but does not mean anything under that frequency is not affected.
Jun 23, 2022 at 10:58 AM Post #15,285 of 19,075
Why would I think that when I specifically mentioned the diameter/radius of wire twice?
Extremely little (insignificantly) with the quality of copper and silver plate. We’re only talking about relatively small amounts of current in an audio signal and Litz cable for example, can make a big difference but for radio freq signals, up to about 1mHz, not for signals in the audible range.
Of course I am, because they’re irrelevant within the range of audible frequencies, audio signal currents and gauge of consumer audio cables.
True, it just means the effect is so small within the audible band of freqs that it’s inaudible and irrelevant.
G
