ProjectDenz
- Aug 1, 2010
Will Symphones make a replaceable cabled version of the Magnum upgrade?
I do not believe so, but you should contact Rhydon to find out.
I have a feeling that he is, given that he is nearing the end of the Magnum productions.
When I sent mine in, he said he had about 12 full Magnums left and then he was done.
If you do the full Magnum, be wary before you move the rods up and down. Rhydon's rod blocks, while substantially better made than Grados, are slightly wider. Grados are so narrow that the rod holder on the headband is frequently glued on not-so-straight. As a result, when you get the bigger rod blocks they can do some damage to the headband. So, before you use them just make sure that you check that and adjust the rod holders accordingly. It just means a little bit of pivoting that is not a big deal at all.
