K_19
- Sep 29, 2008
Plonter, knowing the bass amount that you like, I'm not sure if the SRH840 will have satisfying enough bass for you. If HD650 seemed like it was just a bit short for you in the bass department, 840's aren't going to be that much better... as a matter of fact, I personally think there's less bass quantity wise than 650's. You may be able to change the signature to a bassier one with a right kind of amp, though... but probably not to the level that you're looking for. Overall these have relatively flat response for a closed can. I'm personally using my EF1 with Mullard long plate which brings out the mids bit more and makes their mids more SE530ish, but Tung Sol Black Glass helps with better bass if I want it. As for the 530 comparison, they're definitely more similar than dissimilar, but there are some notable differences... the mids are not as upfront/silky on the 840's and I felt that the 530 did the bass better also in terms of extension (but 840's have much better highs, soundstage, and positioning).
Originally Posted by plonter /img/forum/go_quote.gif ok...that's a good start, thanks. I also assume they got more punch in the bass since they are closed can and can be more suited for electronic music? |
