Jan 28, 2014 at 9:05 AM Post #3,316 of 3,353
Actually, I use the metric system too! I just live in the US now so I'm just putting up with the measurement system here (that my woodshop uses) =)
So for a tight friction fit, would you say it would be best to just measure the outer diameter of the driver, cut out holes that are exactly that size, and sand it until the drivers fit? I've been drilling the center of my cup on a drill press using two circular drill tips: 1 7/8 inches 1/4 inch in, and 1 3/4 inches the rest of the way through. I can't get any more granularity than that using the drill tips available, and these measurements currently don't give me a tight friction fit. The CNC machine will probably offer more precision, so I'm planning to use the exact measured OD of the drivers for these holes when I make them on the CNC machine.
You don't necessary need a friction fit, as you could just find some material to interface between the drivers and the cups. Especially since you've already finished a pair. For your new designs tho, I would definitely go for what you mentioned: approx. 46mm ID of the cups and carefully sand the inside until you feel that the driver can be pressure fit comfortably (remember that the wood will shrink and expand depending on temperature and humidity if the wood is unfinished. This can translate into cracking cups if they're too tight). I usually also round the sharp edges of the glue residue by carefully sanding the drivers by hand.
Notice how the driver OD is approx. 46mm and +-6,5mm high. The next portion has an OD of approx. 44mm and +-3mm high. This usually means that you need at least a 10mm deep slot, of course depending on the ID of the cups.
Jan 28, 2014 at 9:13 AM Post #3,317 of 3,353
for the cup design I had made, the wood turner and I agreed to leave a little leeway because of the expansion/contraction mentioned above. I use foam tape to seat the drivers securely.
Opinions differ on how this affects sound. Some say it is a negative thing (the driver is isolated from the wood and its sound is no longer colored by it), others say its fine. I fall into the latter category. I have found the tape actually provides a better sound and the fit is secure with no potential rattling/movement.
Feb 28, 2014 at 5:33 PM Post #3,322 of 3,353
Does anyone around have a spare SR60i driver around? Doesn't matter if it is modded.
Managed to break one with crappy soldering when changing the cable. Too much heat applied, oh well.
It'd cost way too much to send the cans to Grado for service.
Willing to pay for the driver + shipping via PayPal if you have a bit of posting history.
*fingers crossed*
Mar 5, 2014 at 5:46 AM Post #3,324 of 3,353
  I think you could use px100ii drivers, that could be quite a interesting experience (look at the Non grado drivers thread).
does anyone have any experience with comparing these to any of the prestige series here? The px100ii driver i mean
Mar 10, 2014 at 10:42 AM Post #3,326 of 3,353
Oh darn, it looks like I busted my Grado cables while putting them into my wood cups! I'm a total newbie with a wire mod, but would anyone be willing to help me make a custom cable using a Mogami W2893 (something like http://www.overclock.net/t/631938/a-pic-by-pic-grado-sr80-recable-thread)? I'll pay for the service, of course.
Please PM me if anyone would be willing to help! This is urgent as the cans are a gift for a friend, so any help would be greatly appreciated!
Sep 11, 2014 at 2:25 AM Post #3,327 of 3,353
Hey there, I've done a little searching but haven't seen anything come up. Has anyone tried making cups out of mdf? I've seen pvc and the many different wood iterations but not mdf. Seems as though it might be interesting to try  since its generally so tonally neutral in speaker boxes.
Sep 16, 2014 at 9:47 AM Post #3,328 of 3,353
...never seen mdf cups before...would be worth an experiment though I am sure...
Sep 17, 2014 at 9:01 AM Post #3,330 of 3,353
I haven't ever glued and combined sheets of wood for cups I have had made/made myself...but I have seen it done...kind-of:
http://www.head-fi.org/t/665094/v4-5-magnum-must-see-cups
Would be fun to see what the effect is...
