Mar 20, 2022 at 7:12 AM Post #6,841 of 9,222
The update should come in up to 2-3 weeks.
The higher volume output also works for the A35/45/55 players, as well as for ZX300. It will only work while Direct Source is on, and with all formats except DSD and MQA.
On A45 I usually listen at around 80-85, but with the higher volume output I can listen at around 40.
Mar 20, 2022 at 7:24 AM Post #6,842 of 9,222
Are there any downsides to doing this like overclocking a processor to much and burning it out ?
Or higher battery consumption ?
And what is it doing, is it just delivering more volume or is it actually delivering more driving power to better control hard to drive phones ?
Mar 20, 2022 at 2:20 PM Post #6,843 of 9,222
It is actually delivering more volume. Higher battery consumption may occur (going at it logically - I didn't do a test until the battery runs out), and the sound is still clear even at 120/120.
There's basically no overclocking involved. It's more about using something that it's already in the firmware.
Mar 20, 2022 at 2:44 PM Post #6,844 of 9,222
So it’s a lot more gain but not actually more power output (mW or V) ?
Mar 20, 2022 at 2:52 PM Post #6,845 of 9,222
Yes.
This "much higher gain" mode is already being used in certain situations by the player in the stock firmware. More mW or V would mean that in those certain situations the player could just output more mW, which is not happening.
Mar 20, 2022 at 5:21 PM Post #6,846 of 9,222
In any case, besides the increased volume, it also feels like it's a kind of a stronger sound. It seems to drive some speakers I have better - and this comes from the A45.
This could be helpful towards a stronger output via the 3.5 port when going to an amp, for example.
Mar 20, 2022 at 5:27 PM Post #6,847 of 9,222
Looking forward to it although I don’t really need it with my headphones
Mar 20, 2022 at 10:23 PM Post #6,848 of 9,222
Looking forward to testing it with my zx300!
Mar 21, 2022 at 7:15 AM Post #6,850 of 9,222
Is the EU volume cap still on nw-a105? I have conflicting information from reading different sources.
As far as I’m aware nobody has found a way to remove it on the Android Walkmen
Mar 21, 2022 at 7:53 AM Post #6,852 of 9,222
That what I was afraid off. There were some info on reddit that in 3rd version of the firmware it is removed however the information seemed so general that I should have been more suspicious. Thanks.
It's not removed 100%.
Mar 21, 2022 at 8:05 AM Post #6,853 of 9,222
Mar 21, 2022 at 8:15 AM Post #6,854 of 9,222
Mar 21, 2022 at 8:23 AM Post #6,855 of 9,222
