Sony Walkman custom firmware (non-Android)
Jul 17, 2021 at 3:04 AM Post #5,042 of 8,232
That’s great. I was right then. Classic is original FE and Plus is FE2. Let me join the club that thinks this coupled with E is the best sound
No. FEv2 has 2 modes (as has dawn and midnight) where the classic mode is the same as the previous FE fw and plus mode is an enhanced mode (That consumes 20-25% more battery).
These are all the MrWalkman fw
Jul 17, 2021 at 6:44 AM Post #5,043 of 8,232
Thanks, I had lost track of the versions and was getting confused.
Jul 17, 2021 at 7:25 AM Post #5,044 of 8,232
Jul 17, 2021 at 12:25 PM Post #5,047 of 8,232
Yes that’s what I’ve got. What I mean is FE (Plus mode) also known as FEV2?
FEv2 is a dual boot custom firmware. The classic mode has the same tuning as the original FE and the the plus mode has the same tuning as the FE+. This was done to give you that added convenience of having 2 different tunings in your player. Hope that clears it up.
Jul 17, 2021 at 12:46 PM Post #5,048 of 8,232
that’s exactly what I thought. I’ve moved back from Dawn and had numerous folders called FE so wanted to check I had definitely moved to the correct one
Jul 17, 2021 at 9:38 PM Post #5,049 of 8,232
finally got myself a wm1a again after owning them more than a couple of years ago to try out these mods… just a quick question i keep on reading about chameleon 2.0 and FE+ but cant seem to find where to get them? Been backreading like crazy not sure if i missed it thanks in advance… basically i just want to try the 1z sound on my 1A… thanks in advance guys :)
Jul 17, 2021 at 10:05 PM Post #5,050 of 8,232
Then install Midnight as that is what it's designed for.
Jul 17, 2021 at 10:10 PM Post #5,051 of 8,232
Only the current versions of MrWalkman's firmware are available on his website (for the WM1A, that would be Dawn and Midnight): https://www.mrwalkman.ml/p/sony-wm1a-wm1z-custom-firmware.html
Older versions are not there anymore. Maybe someone saved a copy and can send it to you.
Jul 18, 2021 at 1:26 AM Post #5,053 of 8,232
I posted a link to chameleon 2.0 a few pages back. That’s the closest and best representation of the 1Z sound on the 1A. Even midnight adds external tuning. Try Chameleon 2.0 if you want the 1Z sound on 1A.
Here it is
https://www.head-fi.org/threads/sony-walkman-os-custom-firmware-non-android.943661/post-16445031
Jul 18, 2021 at 5:11 AM Post #5,054 of 8,232
Jul 18, 2021 at 8:24 AM Post #5,055 of 8,232
hey @aceedburn , which CFW are you rocking these days ?
