- Jun 22, 2015
OCC Silver
That will be awesomeThe koss porta pros detail retrieval improves significantly gently if placed on high gain (SE) I wish I had some one mod them to MMCX mod so that I could put a 4.4 cable on them
Copper will be warmer, silver will be brighter. Only you can decide as what IEM using will determine. Or you can opt for a mix of boththanks would you buy silver or copper?
Personally, I would get silver, as I find it better for vocals and micro details. Bass heads like copper, I believe. But a good silver cable is good in bass also. As with everything, you get what you pay for, so cheaper prices will (in general), have lower quality materials. But the plus is that you can try more of them, and get an idea of the sound of each, and find out what you prefer. And some inexpensive cables sound very good. One brand of cable that I have found to be very good for the money is HanSound, a Taiwan company. Unfortunately they are not as widely distributed, so need to search for a store that carries them. Or buy online. . They are in general less expensive than comparable brands, and I think they are much better, in each price category, than other more expensive brands.thanks would you buy silver or copper?
Jump to the wagon a bit late but loving the sound so far. Execellent works, @MrWalkman.
In wm1a and fe, is high gain badly affect the sound?
I found I didn't need hi gain with the MDR-Z1R on the 1A or 1Z and max out at volume at 90.I use high gain with no problem with both my Z1R
hello, for those who want more power do it modded by Nayparm.
