And we're back...to the OS topic....
I've done both of the latest editions to my NW-A45 & ZX300 DAPS. Have done very little listening to the ZX300 since then as I have been concentrating on the NW-A45, which sounds a lot closer to what I remember the ZX300 stock sound was. I got the ZX300 so I could play around with balanced mode.
Am very satisfied, to say the least.
One "negative" to bring up is another lost function, not usually mentioned about the NW-A45 post upgrade. You lose the Line Out via the WM-Port. I was used to using this output in the car or with my KEF Muo or output to headphone amp or even a full pre-amp. Using a cheap and cheerful Chinese WM-Port to 3.5 mm plug I got a fixed line out. When this less than robust cable broke I searched for a better (& more costly) replacement & discovered a Furutech cable that to my surprise provided a Variable line out. Battery life confirmed that it was not simply a re-routed headphone output. These no longer function post upgrade.
But I put negative in quotes above as the headphone outs are very clean on both these DAPS, so not a real problem. (I did have to find a better quality 3.5 mm cable for the headphone jack...what a hardship...
And I'm getting even more excited since
I have discovered a relatively painless way to rip SACD's SACD layers to hard drive.
So big thanks to DR. Walkman!
