castleofargh
Sound Science Forum Moderator
- Jul 2, 2011
My older PC still runs Win XP SP3 and when I connect the player to it I can't access the data in the SD card although the computer does recognize the card. However, I don't have the same problem when trying to access the data in the built-in memory. It works fine when using a Win 7 PC though. Does anybody know if there's a workaround to this?
Of course I have formatted the card, selected "SD Card" as the memory to use etc and it works fine in Win 7, but not in XP.
edit: ok that one's one me ^_^. I can't seem to be able to read a post.
did you try to connect using the usb connection option (bottom of common settings)?
else don't you have a card reader? transferring on a card reader is always so much faster than going through a DAP that I pretty much always use a card reader instead.
