- Jun 22, 2015
MeWalkman's Midnight v2 (for ZX300/A)how to improve soundstage on zx300 please
Thank a lot.What is bass adjustment?fe v2 either project zMeWalkman's Midnight v2 (for ZX300/A)
Quick question @MrWalkman
I think i have successfully installed the Midnight v2 version where my unit is showing Midnight v2 (ZX300) - Plus v2 mode... is plus v2 mode enabled by default?
And thank you very much for all the love you show for the zx300.. appreciate it a lot!
EDIT:
Do the values maked with a red arrow need to be changed and the device restarted for them to take effect?
Thank you very much. Just tested it out while taking a short walk and wow the difference is definitely worth the wait.Yes, the Plus v2 mode is enabled by default.
I think in a future release I'll default it to the Normal mode, and then people can choose themselves.
Yes, you need to change those values.
Though the gain mode is set to normal by default it can be changed in the settings of the player and will remain so till the player is restarted (is that assumption correct?)
where can i find these setting config ?Quick question @MrWalkman
EDIT:
Probably Wicke's or Homebase; they will have plenty of black paint in stockLoving my zx300 after a couple of years with it, but regretting buying the silver version and not that awesome looking all black variant. Where’s the best place to look if I wanted to get my hands on the black one these days?
