Sony NW-ZX300
Jun 26, 2021 at 11:26 PM Post #12,392 of 12,862
Finally i got my zx300 after 20hrs on stock tried Mrwalkman FE version, more details now and i love it Thanks to Mrwalkman!
Edit: ZX300 more holographic than my LG V50
Is it a new one? If so you will notice the difference as the capacitors burn in.
Jul 4, 2021 at 3:13 AM Post #12,393 of 12,862
Just installed MrWalkman FEv2, sounds amazing using the plus setting (not sure how much of an impact it will have on the battery).
Jul 12, 2021 at 2:02 AM Post #12,394 of 12,862
Has any ZX300 owner heard the Lotoo Paw 6000 ?
I'm able to get the LP6K for a deal and would like to know if it's a worthy upgrade.
The fact that the Mr.Walkman FW improves on the stock ZX300 just makes the decision more confusing.
Aug 22, 2021 at 11:45 PM Post #12,396 of 12,862
Has anyone been able to use the zx-300 in DAC mide with an iPhone? If so, how are you connecting them? They don’t seem to work and I’m using the original Sony cable with the USB 3 camera connector from Apple.
You can connect to the iPhone via Bluetooth and use the zx-300 as a BT receiver.
Aug 23, 2021 at 9:05 AM Post #12,397 of 12,862
Yes, that’s how I always use it and it works great. However, I wanted to try high res files from Apple Music and streaming via Bluetooth is not high res. That’s why I thought of connecting it with a cable and use it in dac mode. Is dac mode supposed to work with iPhone?
Aug 23, 2021 at 9:31 AM Post #12,398 of 12,862
Hi
I have also found that often the connection can take a little bit to get up and running. Remember to uncheck in the ZX300 settings (USB DAC Settings) "Load this player from the connected device". And launch 2 or 3 titles on the iphone. I just tried. It worked on the 3rd track. I never understood why this connection was so temperamental at startup. Good luck (I hope someone can give you a less empirical answer here).
Aug 24, 2021 at 10:11 AM Post #12,400 of 12,862
Hey, So I’ve had my ZX300 for about a year now and it seems like the 3.5 MM Jack began disconnecting itself when there’s movement and I noticed the hole itself wobbles a little. Any idea on how I can fix it or replace it?
Buy a 4.4mm balanced cable. :smile: That's probably not the answer you were looking for but apart from taking it somewhere for a (probably expensive) service, it's about your only option.
Aug 24, 2021 at 1:06 PM Post #12,401 of 12,862
Already ahead of you :gs1000smile:, but I use 3.5 for car rides and it’s bugging me having to keep fidgeting it around (also it’s unsafe haha) also I like switching between balanced and unablanced for comforts sake (my ears are sensitive with in ear headphones) or I go walking. Another note is that i tend to yank the unablanced cable in exercise so it might have something to do with it.
Sep 6, 2021 at 5:21 PM Post #12,402 of 12,862
Sep 7, 2021 at 1:23 PM Post #12,404 of 12,862
With the latest firmware (Midnight v2) the ZX300 punches so far above its weight class its a bit ridiculous. I also own a 1A and a feel that the improvement on the ZX300 is even more striking. The ZX300 isn't the most resolving player, so it really seems to benefit from a firmware based on the sweeter, more analogue signature of the 1Z.
