Sony NW-ZX300
Discussion in 'Portable Source Gear' started by riotgrrl, Jul 10, 2017.
455 456 457 458 459 460 461 462 463 464
466 467 468 469 470 471 472 473 474 475
  1. Redcarmoose
    This here. This one!
    koven, equalspeace and knudsen like this.
  2. crabdog
    Just joined the ZX300 club. Reasons I chose this over the DX150:
    - 4.4mm output (without having to pay an extra $200 for an extra amp module)
    - Battery life. Too many DAPs are like smartphones - going for slim form factor over outstanding battery life
    - LDAC - still very few DAPs with aptX HD but several Bluetooth DAC/amplifiers and headphones becoming available
    - Size and weight feels so good in the hand, as does the matte glass touchscreen
    What I don't like: proprietary connector
    The FiiO M7 might have been a good alternative but I'm still salty over the train wreck that the X1ii was. :D
    Am loving it so far. Pairs exceptionally well with the IE 800 S and EE Bravado. It makes the AR-M20 sound a bit dull in comparison.
    YCHANGE, superuser1 and Signal2Noise like this.
  3. Signal2Noise
    In some circles that would be considered a "side-grade". I think you know that considering you quoted 'upgrade':wink:
  4. Shane D
    LOVE my ZX 300! Put it to work last night with my Z7's and my KK balanced cable. Just amazing. SE low gain was way too quiet. SE high gain was undoubtedly louder, but the same. Balanced low gain was definitely better. My final resting spot is balanced, high gain and running at a volume of about 65, out of 120. The cable is great, feels/looks nice and is much shorter than the standard Z7 cable. And the blue miter box is beautiful! Goes on in about 10 seconds, but takes about five minutes to get off due to the rubber back rubbing again the material inside the case.
    I am very, Very happy with this purchase and finally completed my home set-up. These really do pair wonderfully.
    :L3000::L3000::L3000::L3000::L3000::L3000::L3000::L3000::L3000:
    I will try the Grado's tomorrow, but they are VERY easy to run and the SE low gain will likely be all they need. But I will probably try the high gain anyway.
    Also, I am thinking that this balanced cable would probably work with my Meze 99 Classic's...
    Shane D
    Hinomotocho likes this.
  5. Shane D
    Sarcasmo likes this.
  6. koven Contributor
    Yes indeed.. :p
  7. sklaus28
    Im coming from WM1A as well :p Had ZX300 at first then bought WM1A and now going back to ZX300. I dont feel anything missing
    Audiophile2019 and Mathieulh like this.
  8. superuser1
    Welcome to the club! :)
    kms108 and crabdog like this.
  9. Erfan Elahi
    True, In China, you can get both 16 GB version and 64 GB. I just bought one and it's being shipped. Don't know if the sound quality will be the same or not like the Japanese version.
  10. pr0b3r
    Been waiting for my ZX300 coming from Opus#1. I wonder if there are any users of that same DAP. It would be nice to hear some impressions/comparisons.
  11. Lookout57
    I have the Opus #1 Metal and found that the ZX300 is better in all area, bass, details, soundstage, battery life and UI.
    Before the OPUS I had FiiO a X5 Gen 2 and thought that the OPUS was a big step up. Going to the Sony was a bigger step up.
    pr0b3r and crabdog like this.
  12. jonathane40
    This has been asked before but it seems there wasn’t a definite answe. Does anyone know what is the output impedance (OI) for the ZX300 in SE and Balanced? I think someone said that it was around 1.6 but it wasn’t for sure.
  13. pr0b3r
    Thank you! I always had the impression that Opus#1 still have the wider stage compared to most DAPs that I have tried. I had the chance to use the X5ii as well but only for a week and I felt that it was brighter than what I prefer. I hope my ZX300 arrives tomorrow. Can't wait to be impressed by its build and overall premium feel compared to the plastic and bulky Opus#1. More importantly, I hope that its sound will grow on me as I have auditioned it only briefly during local audio meet ups.
  14. yomiura
    https://ibb.co/g3a12T
    [​IMG]
  15. jonathane40
    Thanks for the info. However, I don’t want to know the maximum power the dap can output st a specific resistance. I already knew that.
    The output impedance of a dap is a different thing. I don’t know how to explain it but it matter when you are using bakanced iems with very low resistance. Here is a quote from NwAvguy’s blog that explains a bit about it:
    THE SHORT VERSION: All you really need to know is most headphones work best when the output impedance is less than 1/8th the headphone impedance. So, for example, with 32 ohm Grados the output impedance can be, at most, 32/8 = 4 ohms. The Etymotic HF5s are 16 ohms so the max output impedance is 16/8 = 2 ohms. If you want to be assured a source will work well with just about any headphone, simply make sure the output impedance is under 2 ohms.
    I believe one person said the output impedance of the ZX300 was 1.6 Ohms and that somebody had shown the measurements here but I can’t find them.
