Sony NW-ZX300
Discussion in 'Portable Source Gear' started by riotgrrl, Jul 10, 2017.
432 433 434 435 436 437 438 439 440 441
443 444 445 446 447 448 449 450 451 452
  1. colonelkernel8
    But it’s not their full leather one :frowning2:
  2. colonelkernel8
    It’s on there quite prominently, 3rd from the top by price. Just don’t click on High Resolution Audio under Electronics and instead go to “MP3 Players”. I think it’s just the High Resolution Audio page that’s out of date. 64D35D7B-EF9D-49E5-ACFD-FD863EDA3DB8.png
    knudsen likes this.
  3. yomiura
    Hello guys,
    There is a nice deal for ZX300 in my country so I am quite intrigued to replace my old FiiO X3-2. Thing is, I tried the demo kiosk of zx300 + MDR-1ABP through its balancd port. The sound it make was very great. However, when I switched to test the standard 3.5mm port with my Shure SE215 the sound fall so flat and very bad compare to my main pair of SE215 + FiiO X3-2. SE215 supposed to be a very easy pair to drive, but even with WM1A, the sound was completely worse than how I listening to it through X3-2 everyday. This issue pushed me away from purchasing ZX300 to find more information. Is it normal for Sony player to be like this? Or haye I done anything wrong?
  4. twice tzuyu
    It could be that the unit has not been burned in sufficiently yet
  5. superuser1
    The fiio is rated as >224 mW (16 Ω/THD+N<1%) and the zx300 SE as 50 mW @ 16Ω. The difference in power itself will change the sound IMO or the lack of it. I would say the synergy is not great. looking at the 215s specs and its sensitivity being 107 dB SPL/mW it shouldn't need a lot of power to drive it. Wonder whats happening..
    cthomas and kms108 like this.
  6. geagle
    yeah, ZX-300 really sounds better when fully burnt in, and according to Sony it will need 200 hours on each port, balanced and SE, separately, to reach that state. It could be that the balanced port on that demo unit is fully burnt in as more people try that out, compared to the SE.
    Do keep in mind, though, that most people who heard both the 300 and the WM1a say that the balanced on the 300 is very similar in quality to the WM1a, while the SE is lower level (compared to the SE on the WM1A). personally, I like the sound from both (my SE does not sound the way you described it - which would translate to "awful" :) ), but I do like the sound from the balanced port better.
    Ryokan and superuser1 like this.
  7. goody
    The SE port on the ZX300 was not as good as my ZX100 when i had it but the balanced port was great ..that is the magic of this player
  8. GreenBow
    Have read all the ZX300 thread. Keep getting so close to buying one.
    Then today I noticed that the ZX300 is sold out on Amazon UK. However there a handful of Amazon Warehouse ones that are opened. Presumably sent back by customers, that are opened so can not be sold new. ..... I was actually considering an Amazon Warehouseone anyway, just to save some money.
    The plus side of buying an Amazon Warehouse ZX300 is:
    1. I can get the ZX300, listen to and if I return, which I won't, because I'd love it like you folks. Meaning I wouldn't be returning a new one that I had opened, either way. Cool for everyone.
    The negative side, or my worries are:
    1. The ZX300 might have a fault which I might not notice for a long time. (Like e.g the balanced port doesn't work.) That might be why it's a returned item. (You know how they say Amazon et al, resend out stuff that gets returned when claimed faulty.)
    2. The warranty period on only 30 days in effect. You have 30 days to assess if you want it. If it goes faulty after that, you lose out completely. There's no Amazon guarantee with warehouse stuff.
    3. Not sure how reliable the Sony warranty is. Or if it would count on an opened product. I have read the odd scare story of Sony being hard work to deal with over warranties. .. I can't even figure out Sony's warranty anyway.
  9. geagle
    Personally, I got a ZX300a from Joybuy... only difference is 16gb instead of 64gb internal memory, but it costs way less. IF things should go south, I have absolutely no idea of how the warranty would work, tbh, so do keep that in mind... BUT 1) fingers crossed nothing has as yet happened :) (and it's been 4 months or so), and 2) even if something does happen and there should be no recourse (don't think that would be the case, but it's certainly going to be less convenient than with, say, Amazon) you can almost buy a second one with what you save :) (not really true, but at least partially so:))
    GreenBow likes this.
  10. KaiserTK
    I also bought a ZX300 (used) lately to replace my old X3ii and my first impression with the Sony's SE output was that it lacked the proximity and punch of the X3ii, but after a while I started to appreciate the amount of detail and smoothness of the Sony. But be wary of trying to power headphones out of the SE output since High Gain mode barely does anything. After I got my 4.4mm balanced setup going for my IEMs I was really happy with the upgrade in sound.
    superuser1 likes this.
  11. colonelkernel8
    It just comes down to voltage I think, particularly with multi-driver or hybrid IEMs. These Sony players, when using SE out can only push as much voltage as the small, single cell lithium batteries can output, which is going to be tiny; they aren’t boosting the rail voltage AFAIK. That’s the value of the balanced operation since it doubles this maximum voltage.
    Burn in of solid state electronic components is an utter lie. Of course Sony wants you to play it for 200 hours. It’s a great marketing gimmick to get you to keep the product and get used to the sound.
    Intensecure likes this.
  12. sklaus28
    And get to past the 14 days return window.
  13. EJD87
    Hi all, I just got a ZX300A. It sounds great, but I;m having major problems with data transfer. I'm using Music Center, and while the songs seem to be transferring to the microSD (Sandisk Ultra 200GB purchased from Amazon) and they show up on the card when the player is attached to my PC, on the player itself some of the songs won't appear. How do I fix this? I've tried rebuilding the database, resetting to factory defaults, reformatting the card (which is currently in exFAT), but nothing. This doesn't affect all my music, just a small portion, but it's extremely frustrating.
  14. superuser1
    One word of advice.. just drag and drop as you would inside an explorer window. Works much better than Sony Music IMO.
    knudsen likes this.
  15. EJD87
    Tried that too. It creates a file that’s visible within the player (the name of the album) but doesn’t actually have music in it. Of course, when viewed on the PC, the whole file shows up intact, right where it’s supposed to be.
