superuser1
From what i have read, the minute you engage the balanced out the SE is cut out.
You select which output is used via the menu, I don't believe you can have both play at the same time because of this.Maybe a dumb question but....
Can you hurt the device if you play while having both SE and balanced plugged in at same time? Will it output to both or default to just one? I'd love to A/B the outputs at the same time but thought it safer to ask first.
I dont think thats right.You select which output is used via the menu, I don't believe you can have both play at the same time because of this.
You can plug in both at the same time, but balanced take priority above SEMaybe a dumb question but....
Ack! Really? I keep setting this manually in the menu ...From what i have read, the minute you engage the balanced out the SE is cut out.
That's the high gain you were activating (high gain is for those times when you've got power hungry headphones, no need to activate it with most in-ear headphones)Ack! Really? I keep setting this manually in the menu ...
I've been listening to Bon Iver's For Emma, Forever Ago on the ZX300 (SE). I used to dismiss it as some plebs music, but really loving it on the ZX300. Or maybe my taste has changed
I searched for the diagrams but could not find anything. Do you have a link?
Any memory card that states micro sdxc class 10 will do.Alright guys, forgive me because I don’t know much about memory cards and such, but I would like to get a memory card for the zx300. What’s the minimum class I need for it to work with high Rez files. Trying to keep costs down. How much should I be paying for 256gb ideally. They seem to run the full gamut. Different classes, speeds, etc. do I need one for 150 dollars or will a 25 dollar one work? This is all new territory for me. Thanks. Links would be awesome, if you’d be so kind. I’m at a family dinner right now, and all I think about is getting home to load my zx up with music, albeit on the on board memory. Lol.
