By the way, the update to FW 1.10 was very fast (2-3 tops)
Sony NW-ZX300
Brice d’Oliveira
Personnaly, i’d try to pass it on « E » and see if you have this behavior again, if no it’s a « CEW2 » thing .CEW2 (western Europe). Volume limitation was off out of the box (bought it on Amazon.co.uk, factory sealed, not a refurbished item)
Brice d’Oliveira
Ghost on rockbox wiki it’s write for « CEW2 » >>> capped and volume warning (check the volume level at some point)Curious thing happened to me today. I was listening to that wonderful dutch group 'De Staat' when suddenly I heard 4-5 beeps and then the music stopped. 8 hours since last full charge, I thought 'not the battery already!'.
I reached to the player in my pocket. It wasn't off but there were a volume message warning (too high). Weard thing since player is uncapped.
Volume was 103.
Maybee it’s your answer, pass it on « E »
I can go to 120 without a warning.
The strange thing is that happened during playback.
Brice d’Oliveira
Maybee « this » is why (check the volume limit at some point)I can go to 120 without a warning.
... maybee after some time at some level
Has anyone tried the zx300 with campfire andromeda? How's the sound with them? Any hissing?
musicdragoon
- Sep 20, 2014
1
No hissing at all, just can heard a little tick sound before playing a dsd track, maybe a process switching sound for native dsd? No noise during song playback, andromeda’s sound signature seems like a perfect match with what zx300 can reproduceHas anyone tried the zx300 with campfire andromeda? How's the sound with them? Any hissing?
1
I'm torn between a used ZX2 and the ZX300. I don't use streaming services so ZX300 might be a good choice after all you said.
Are you using balanced or SE? I heard balanced is a whole lot better on this device.
psikey
- Jul 15, 2008
If you don't use streaming then easily it's the ZX300 vs the ZX2 for SQ, size, ease of use. I've had both.
Balanced best but SE great too.
Partlys4int
- Jul 12, 2015
@Brice d’Oliveira Any idea what you're going to do next? If I were you, I would push Sony support France really really hard. I did it back then with my Vaio laptop.
Sometimes you have to persevere as nicely as you can I wouldn't lose hope, there's no hardware corrupt on your player so it seems a full reset would do the trick, but I can't fidn it in the user guide/
Partlys4int
- Jul 12, 2015
From what I gather, the only thing that used ZX2 would have going for it, is that it will be burned-in already. The ZX300 will need some 200hrs for each output.I'm torn between a used ZX2 and the ZX300. I don't use streaming services so ZX300 might be a good choice after all you said.
And the SE is very good on the ZX300. I've completely forgot about the balanced output, as I'm so enjoying the SE, even though I've only 100hrs now.
The burn-in process on this device is very real btw. The changes in sq are quite substantial with each 50 hrs.
Is there a counter in the settings to tell you how many hours burned through each output?From what I gather, the only thing that used ZX2 would have going for it, is that it will be burned-in already. The ZX300 will need some 200hrs for each output.
Sorry to repost this but I’m still confused. What is the best way to add music with a mac? Add all of the albums to a MicroSD card directly from Mac first, then insert the card into the zx300? Or insert the empty card first into the zx300, and then use Content Transfer to move files over to the zx-300 that is connected to the computer? I have about 184GB of music to add, and a 200GB card, and both the player and the card are currently empty..
superuser1
I would suggest you insert the card into the DAP and format it and then start copying music onto it.Sorry to repost this but I’m still confused. What is the best way to add music with a mac? Add all of the albums to a MicroSD card first, then insert the card? Or insert the empty card first, and then use Content Transfer to move files over to the zx-300 that is connected to the computer? I have about 184GB of music to add, and a 200GB card, and both the player and the card are currently empty..
AudioBear
- Mar 3, 2007
I inserted the 200Gb card into my Macs USB 3.0 port using a SD to Micro USB 3.0 adaptor. I named and formatted the card to Exfat using the disk utilty. I transferred files on the Mac to the card. A Gb goes in a few seconds. It’s very fast.
Edit: I don't have a ZX300 to compare with because they are still not on sale in the USA so I can't tell you if this is faster than doing it in the ZX300.
Total: 21 (members: 0, guests: 21)
