Sony NW-ZX300
Discussion in 'Portable Source Gear' started by riotgrrl, Jul 10, 2017.
181 182 183 184 185 186 187 188 189 190
192 193 194 195 196 197 198 199 200 201
  1. Ghost2501
    Sony was saying that battery time with FLAC will be 24 hours. My ZX300 is playing since yesterday 21.00pm. So for now, after 12 hours straight, there is only one bar left on battery level.
    I think that it will not reach the 24 hours.
  2. superuser1
    Balanced??
  3. Ghost2501
    No, standard output.
  4. superuser1
    that makes me a bit worried
  5. Ghost2501
    Volume level @100
    Maybe the battery improves after several charging/discharging cycles.
    Some settings may also have impact on battery life : EQ, DSEE HX,...
    I will try next run with FLAC, Direct Sound et volume 75.
  6. psikey
    I have Bluetooth and NFC also turned off on mine. I also tend to turn mine fully off when not in use.
    Do you turn ZX300 off between playing or is that 12hrs none stop? I'm also only at a volume of 55/120 balanced with my SE846's. No other setting (EQ etc)
    I will do a test soon.
  7. Ghost2501
    It's a non stop playing test (EQ and DSEE HX turned on, FLAC files only).
    Playtime is just 14 hours right now.
    psikey likes this.
  8. Ghost2501
    I'm definitely going to buy a balanced cable because of all those positive returns from you guys.
    Going for the Null-audio one.
  9. psikey
    To be honest at 14hrs plus I'd be OK. Much better than 6-7 I got out of Mojo (or under 9 with Fiio X5III).
    I bet volume plays a big part. Would expect the figure of 29hrs to be based on 50% volume with all DSP off.
    Ghost2501 likes this.
  10. saykong
    How Fiio X7 II compare to Sony NW-ZX300 in SQ?
    Can't decide which to buy.
    Thanks.
  11. Ghost2501
    So, the message 'Low Battery' just appeared on the display after 15 hours of playback.
  12. psikey
    You didn't say if you had BT/NFC turned off ?
  13. kms108
    Lets just say, without sony's test procedures and settings, you will never get the same results, just be lucky if you get a differences of 10-20 %, look at it this way, Sony's DAP offers the best battery life on the market.
  14. superuser1
    Some Cowon DAPs have been known to have performed really well re: battery.
    I am worried because these numbers are based on listening on SE. I shudder to think if i will get 8 hrs from DSD balanced listening?
    kms108 likes this.
  15. kms108
    IEM, headphones, music files, bit rate, volume, normal/high gain, files running on internal/external memory, button pressing, DAP settings and player running on one file or two or more files all contribute to the battery life. in theory, just take the official battery life with some mark off.
    with my ZX2 I get enough battery life for about 10 days, for my ZX300, it's about 5 days.
    superuser1 likes this.
