Sony NW-A40 Series NW-A45/A46/A47
Discussion in 'Portable Source Gear' started by bizkid, Jul 11, 2017.
76 77 78 79 80 81 82 83 84 85
87 88 89 90 91 92 93 94 95 96
  1. luisdent
    I've used easytag successfully with mint linux. works great too. just have to be sure you fully apply the album art (it's a slightly odd procedure). that works with flac.
    dannydj likes this.
  2. dannydj
    Heads up for those in the UK the player is £114.99 at Amazon today only - blue, red, black and gold.
  3. luisdent
    64C98166-3373-409B-B6C4-4D9E79E052E9.jpeg absolutely loving mine.
    Krutsch likes this.
  4. se7en7
    WIth the Sony NW A45 from uk what is the latest firmware everyone is on thank you
  5. Gosod
    What changes you found in this firmware?
  6. pinkbecca
  7. Eighty8
  8. DuncanF
    On Amazon UK until midnight tonight (30-Nov) the NW-A45 is available in blue or black at GBP115 as a "deal of the day".
    funkymartyn likes this.
  9. funkymartyn
    Just to clarify, I have all my music on my lap top windows 10. I load my cds onto winows media player. ...And just drag and drop into my mp3 audio players. With the art work. Some I havery to paste myself if not found. Via Google images.
    So this Sony will be OK with my music then ?
    I have read about some artwork might fail.. but apart from that will I be OK.
    Thanks in advance..... Amazon UK might be getting a order soon if I'm ok
    I load in wma not in mp3
  10. bruce1967
    Regarding the album artwork I found a good site for finding good quality images - https://bendodson.com/projects/itunes-artwork-finder/. I guess it has anything that might be in the itunes store. I find it useful at times.
    defbear and funkymartyn like this.
  11. funkymartyn
    Can it play wma I don't use mp3
  12. bruce1967
    I don't think it supports wma.
    Here are the supported formats:
    MP3 ( .mp3)
    32 kbps - 320 kbps (Supports variable bit rate (VBR)) / 32 kHz, 44.1 kHz, 48 kHz
    WMA ( .wma)
    32 kbps - 192 kbps (Supports variable bit rate (VBR)) / 44.1 kHz
    FLAC ( .flac)
    16 bit, 24 bit / 8 kHz - 192 kHz
    WAV ( .wav)
    16 bit, 24 bit, 32 bit (Float/Integer) / 8 kHz - 192 kHz
    AAC ( .mp4, .m4a, .3gp)
    16 kbps - 320 kbps / 8 kHz - 48 kHz
    HE-AAC ( .mp4, .m4a, .3gp)
    32 kbps - 144 kbps / 8 kHz - 48 kHz
    Apple Lossless ( .mp4, .m4a)
    AIFF ( .aif, .aiff, .afc, .aifc)
    DSD ( .dsf, .dff)
    1 bit / 2.8224 MHz, 5.6448 MHz, 11.2896 MHz
    *Audio that is converted to Linear PCM is output.
    APE ( .ape)
    8 bit , 16 bit , 24 bit / 8 kHz - 192 kHz (Fast, Normal, High)
    MQA ( .mqa.flac)
  13. funkymartyn
    It does say wma second one down....
  14. Eighty8
    Artwork won't display if the JPEG format is either "optimized" or "progressive". It needs to be "baseline" for the player to display it correctly. All photos from Google images are in baseline format and will work no problem.
  15. bruce1967
    Oh I missed that! Well there you go then :)
