I just can't do the Sony after getting used to my Planars. It has an obese waddling low end, in comparison to the i4. Acoustic music suffers a lot here.I don’t think it has much to do with quantity. For example, the CA Vega was very “bassy“ but the bass was pretty fast for a DD. The bass had quick attack and quick decay with plenty of quantity. The difference in speed is very noticeable on acoustic tracks in an A/B comparison.
SONY IER-Z1R
- Thread starter leylandi
jmills8
Previously known as bmiamihk, jmills2
Yeah the sony has more bass.I don’t think it has much to do with quantity. For example, the CA Vega was very “bassy“ but the bass was pretty fast for a DD. The bass had quick attack and quick decay with plenty of quantity. The difference in speed is very noticeable on acoustic tracks in an A/B comparison.
jmills8
How does the SNARE drum sounds on this iem from this track ?
- Sep 13, 2007
I can already tell you that with the 128 mp3 that youtube provides it will definitely sound like crap no matter what IEM you use.
jmills8
Obvious , but I have it in WAV.I can already tell you that with the 128 mp3 that youtube provides it will definitely sound like crap no matter what IEM you use.
gerelmx1986
It's safe to clean the IER-Z1R with LCD-Screen cleaner?
candlejack
You can clean it with a wet napkin as long as it's not soaked. Definitely don't spray it directly.It's safe to clean the IER-Z1R with LCD-Screen cleaner?
mvvRAZ
I’d recommend a sunglasses tissue personally - no need to expose it to unnecessary humidityIt's safe to clean the IER-Z1R with LCD-Screen cleaner?
gerelmx1986
Yeah that's what I am doing, spray on the sunglasses cloth and then wipe Z1R cleanI’d recommend a sunglasses tissue personally - no need to expose it to unnecessary humidity
Peter Ruby
Agreed. I use a soft terry cloth towel I spray a little water on that clean mine. I use soap to clean the tips after every use.
Do not use paper towels. They will leave micro scratches on them.
BramblexD
- Feb 20, 2015
Does anyone else have the problem where Comply tips don't "grip" enough onto the Z1R? (Compared to the Sony's silicon ones)
I use the silicon M for my left ear and comply M for my right ear, and the comply tip gets stuck most of the time when taking it out, so I have to manually pull it out with my fingers.
Might just be the shape of my ears that causes it.
- Oct 14, 2013
I have no problem with those foam tips. Love it most of the time
nc8000
Are you using the right size Comply (they come in 4 bore diameters) ?
BramblexD
- Feb 20, 2015
I believe it is, it fits snugly, just the inner layer doesn't provide as much grip as the silicon.Are you using the right size Comply (they come in 4 bore diameters) ?
Yes I have had the same problem with Comply tips, weirdly it was only my left ear at first, and then the right did it too. Once they have pulled off once that is it they will no longer grip onto the IEM and will pull off every time so are rendered useless and the foam usually gets damaged on trying to get it out of my ear. I'd put it down to how deeply into my ear canals I was able to get them, but annoying all the same especially when it happens when not at home! The solution to this problem for me was to put a small layer of Kapton tape around the IEM stem before putting the Comply tip on and I've had no issues since, other tapes might work. Maybe I have weird ears too?!
