Exactly, which raises the question. Does it have computing power to render vertical for two users?
In that perspective, I would prefer the interpretation meaning that vertical elevation is not even implemented in single user mode and that in the future it will have computing power to render vertical headtracking for dual users individually.
I think we are miscommunicating here, I should have said it better I guess:
It will initially not have vertical head tracking. Not for one user. Not for 2 users. This by the way was already mentioned in one of the updates months ago. I am pretty sure the first prototype
didn't have vertical head tracking either.
What other operating modes and features that are missing (beside the DTS-X and Auro3D decoding ) and may or may not be introduced in the future as firmware updates ?
1. Indeed no elevation head tracking.
2. No measurement sweep over digital outputs. No asynchronous PRIR measurements with sweep disc. (With this method you can just play the disc with sweeps on a system without having to connect the Realiser to the sytem, and when just playing the sweep disc all digital processing, in particular room correction/EQ, will be in effect. Because the sweeps are now only available over analog out we are back to the old problem how to measure a system including the room correction/EQ? Many, if not most, AV Receivers bypass all digital processing when using the multichannel analog inputs, because otherwise they would have had to build in a multichannel AD-converter just for this purpose.)
3. (If I interpret correctly) No special PRIR measurement mode for single speaker measurements, just a complete 16 channel measurement.
Unknown (I hope the user manual will be available soon to answer these questions, or that the first users can figure out and report):
1. Did they implement the parametric EQ already? I sure hope they did because then at least I can try to manually copy the EQ settings from my AV Receiver to solve the above mentioned problem, but I am mildly pessimistic they did.)
2. Did they implement the capability to combine speakers from different PRIRs into one preset? (I expect they will have done this, but am not sure of course.I hope they did because then we can do measurements with one speaker, or some smaller number than 16 by simply making several 16 channel PRIRs with a subset of the analog outs simply not connected so it would be a dummy measurement for those channels. And then combine the speakers from the different PRIRs to one 16 channel setup in a preset. Also by measuring just one or two speakers at a time you can use the room correction/EQ of your receiver because it will work for analog stereo inputs. But if you move the speakers around, or change which speakers are connected to the left and right front outputs of your receiver you will have to re-calibrate EQ with your reciever. So that would be a lot of work.)
