So Im getting ready to run cable from a TCL 65" 4k HDR/DV TV over a fireplace to a cabinet Im using for all my stereo equipment including the A16 which will be about 15 feet away. I have to run the cables under the floor joists because the ceilings are 12 feet high. I plan on using the A16 and the Yarra 3dx soundbar. Im 100% movies, no music, no gaming.
1. What type of cable do I need to run for the A16 headtracker?
2. What is the maximum length of HDMI cables I can run without degradation? (I plan to run 2 HDMI cables, 1 as backup in case the other fails over time)
3. Any suggestion on make and model of HDMI cable?
Am I mistaken about the new head tracker design for the A16? Does it actually still need a wire, and is there still an IR Receiver that sits on top of the TV?
I thought the new design was somehow wireless, used only one piece that was attached to your headphone band, and had a "motion sensor" to detect your head orientation and that there was no longer a receiver of any kind at the TV location. I don't see a head tracker IR REF input on either the front or back of the A16 photos, but maybe I'm wrong.
I do absolutely know that the head tracker technology for the A8, which uses TWO pieces and a wired connection from the IR receiver over the TV to the IR REF input on the back of the A8 unit, is NOT COMPATIBLE with the A16, which i've been told uses a completely different approach. And I could swear I thought I saw that it only had one piece, not two. Am I wrong?
If you know for sure, can someone please clarify how this is actually supposed to work on the A16? Is there written documentation or pictures on this somewhere that I could reference?
As far as cables go, for "premium certified" 4K HDR 60hz 18gb/s 4:4:4 HDMI cable to be used in a modern day 4K world, you can't go beyond 15 ft max with "copper". And even then they get thicker with length. You should never buy any cable which you plan to use in a 4K environment that doesn't have the "premium certified" logo shown on its web page, as otherwise you are not really guaranteed that the cable can actually live up to its specs and not cause you any audio or video problems.
In shorter lengths (say 8ft or less) there are some ultra-slim "premium certified" copper cables which are very nice and also very thin. But not in longer lengths.
The new technology for VERY LONG RUNS (say 20 feet up to 330 feet) in support of the 4K HDR world is to use the new fiber optic HDMI cables, typically containing 4 strands of fiber optic cable inside them. These are also surprisingly very thin and flexible and have no problem running through conduits and making turns through elbows, etc. I have used two of these now, one in a 20ft length and another in a 60ft length, and both work perfectly. These fiber optic HDMI cables are, as expected, considerably more expensive than copper cables. They are also "active" (i.e. directional) in the sense that the connector at one specific end is for use at the SOURCE and the other connector at the other end of the cable is for use at the DISPLAY, due to the "amplifying electronics" and optical-to-electronic converters built into the HDMI connectors themselves.
Typically you will find fiber optic HDMI cables priced starting from around $140 for a 20ft length, and going up from there. But just last week I purchased (somewhat skeptically, but now that it's arrived I'm a believer since it works perfectly) a
20ft Cable from CableCreation (China) for only $51! Fantastic price. They also offer 33ft ($60), 49ft ($61), 66ft ($67) and 98ft ($76). Amazing prices, compared to similar fiber HDMI cables from Monoprice, RUIPRO, Cable Matters, and others. But based on my own experience just this week with their 20ft cable (beautiful build quality in the connectors) I'd recommend these... for value pricing, and still delivering a quality reliable product.
Again, the real benefit of fiber optic HDMI cables, aside from their great lengths with zero loss, is that they're super slim cables and thus do not "stress" the connectors when plugged into HDMI sockets on source/display devices. You could pull two through a conduit without a problem, along with a CAT6 ethernet cable (that you should also pull, in support of smart TV's).
