Where can someone interested have one made?and it supports SOFA HRTFs in case you might have one of those for yourself
Smyth Research Realiser A16
zdjh22
Genelec ($$$) and Earfish ($) both have services. Open source there is mesh2hrtf that can use the data from the 3D face mapping cameras in iPhones and iPads (but applied to your ears and head). There are a set of .m files for MATLAB (and I assume Octave) that let you manipulate .sofa files.Where can someone interested have one made?
I haven’t done any of the above but will probably take a look at mesh2hrtf.
https://www.production-expert.com/production-expert-1/what-are-custom-hrtfs-and-why-they-matter
According to the updates video at , ASIO was added to the previous Windows output options, and is not a requirement.It looks like Virtuoso requires Audio/Video software with ASIO output... Not sure of many video players that have that feature... I think MPC HC, JRiver and Mitch Barnett's Hang Loose Convolver may be supported... I've contacted the developer for guidance in this area.
Screenshot from 3:04 in the video:
I was under the impression that the multi-channel software to be used with Virtuoso needed to be able to support ASIO... 3:38 in the same video.
It's hard to tell from the available information. I think I confused ASIO input to Virtuoso with ASIO output.
I just got a Realiser, and I'm having channel imbalance issues when creating the HPEQ, it seems like the right input is more sensitive than the left one, which results in a channel imbalance (left being louder than right). Has anyone seen this issue? is there an easy way of fixing the HPEQ?
Unfortunately... There is a known bug with fw 2.15 and PRIR imbalance... not sure it carries over to HPEQs... but it also may be a microphone issue... Could be placement or heaven forbid... A bad microphone.I just got a Realiser, and I'm having channel imbalance issues when creating the HPEQ, it seems like the right input is more sensitive than the left one, which results in a channel imbalance (left being louder than right). Has anyone seen this issue? is there an easy way of fixing the HPEQ?
zdjh22
A new A16, with the 2.15 firmware? I have the same issue with mine. Or rather I should say, I had the same issue, then my A16 had to be returned for repairs and I never got around to investigating further because I am now using the HD-800s HPEQ that came with the very fine Omega 65/95 PRIR set from 3D Sound Shop.I just got a Realiser, and I'm having channel imbalance issues when creating the HPEQ, it seems like the right input is more sensitive than the left one, which results in a channel imbalance (left being louder than right). Has anyone seen this issue? is there an easy way of fixing the HPEQ?
I was going to investigate the differential gain setting for the MICs and try new HPEQs - I will add that to a long list of things I promised to play with and report back, unless you find out first that it solves the problem.
The 2.15 firmware has a similar issue with recorded PRIRs.
And, I should note that you need to download the 2.15 firmware notes to get instructions for the differential gain setting. Plus if your A16 is new like mine, we are stuck with no earlier firmware than 2.15 because the ARM computer board and the APM board are both not compatible with earlier.
@elira If you need a HD800S HPEQ... Send me a PM.
Yes, a brand new one with the 2.15 firmware. I think I found a way of just adjsting the balance when reproducing but not when generating the HPEQ, that seems to be working ok, also the flatEQ seems to sound better than the HPEQ I generated, so I'll try that.A new A16, with the 2.15 firmware? I have the same issue with mine. Or rather I should say, I had the same issue, then my A16 had to be returned for repairs and I never got around to investigating further because I am now using the HD-800s HPEQ that came with the very fine Omega 65/95 PRIR set from 3D Sound Shop.
I swaped the microphones (left to right and viceversa), the issue remained the same (i.e. didn't swap channels), so I think the microphones are fine.Unfortunately... There is a known bug with fw 2.15 and PRIR imbalance... not sure it carries over to HPEQs... but it also may be a microphone issue... Could be placement or heaven forbid... A bad microphone.
weijiangnan
Only continue to wait until Smyth updates the new firmware.I swaped the microphones (left to right and viceversa), the issue remained the same (i.e. didn't swap channels), so I think the microphones are fine.
gimlet
Just tested the Virtuoso standalone app on Apple OSX - works well with Roon and plays 5.1 music from Qobuz. Very impressive and totally stable so far. Will probably buy a license for when I am travelling and away from my A16.
esimms86
- Oct 3, 2013
John, are you sending them a “universal” HPEQ?@elira If you need a HD800S HPEQ... Send me a PM.
I started using the flat EQ, both of the HPEQs I made had the channel balance issue, I adjusted the balance but they sound very artificial compared to the flat EQ. Maybe too much processing, is there a better way of getting HPEQs? Using the provided microphones doesn’t seem very reliable.
