gabbabe
- Jun 15, 2005
Hi TruckDriver,
Can you kindly share the v4a setting with me as well?
Thanks!
G
Thanks!
G
Hi TruckDriver,
Thanks!
G
The SE846 black square case is one of most stylish non-drybox case around.
In regards to dry-box I think customised otter box 1000 is most practical. *just* about perfect room inside.
Still have the Heir Audio branded Otterbox 1000. Gave buyer of my 4.ai+ my Peli 1010 with foam. Peli more bulky. Then I guess you are using a man or gym bag regardless of either one.
The SE846 branded clear dry box (in western market packaging) is nice, but like Westone deluxe case is bigger then necessary?
Westone monitor vault is better sizng also but some Amazon reviews question cracking?
An update regarding the looseness of the nozzle (left-earpiece): it has exasperated, badly. Should I be concerned about this? It is nearly 2100 Melbourne time hence, rather annoyingly, I cannot get them seen to (again) by Jaben Audio (and not before another tram ride into town sans music!).
Obviously they are not withstanding the pressures of daily pocket-based transportation. I would like to investigate a good case for them that is pocket sized. I am about to quit the cigarettes hence that will vacate some vital real estate, but what would be a great, pocketable protective case for them?
Another shot of Hippocan for size reference - with HA-FX850 in tow....
Those hippocan's look sexyyyy
Did a quick search online and found these. Only problem min order is 24. Still a lot cheaper then hippocans. Which size think would be ideal for 846?
http://www.zazzle.com/halloween_eye_ball_small_snip_snap_tin_candy_tins-256500850317396029
