ayaflo
Formerly known as turgid & facilitator.
- Nov 29, 2011
how about the fiio e 11 ?? is that a good upgrade?
i want the highest amount of clarity i can get from these ....what would you recommend ?? and my budget is around a 100 dollars
My 535s are up for sale if anyone is interested. Will consider offers.
Hi guys, need some suggestion for a replacement cable for the 535. Can someone let know what is the kind of material used on the stock cable (copper or something else)? There are copper, silver and silver plated copper available but would appreciate some input as to which will works best with the 535. Many thanks.
im not sure what the stock cable is made with. imo i feel the stock cable is great in its own right.
if you can get a silver cable i suggest that. its what ive been using with my ltd-j's and personally i cant find a fault with it. silver seems to do everything better than copper or silver plated copper.
Hi Mooses9, I also think that the stock cable is great by itself but the weight is really uncomfortable for long listening session. Silver seems to be a popular choice and have read that it has a brighter sound compared to copper. What's the changes you experience on the SQ with silver cable as I see in your signature you own a silver cable. Many thanks.
i personally have no expierence with the toxic cables. but have heard nothing but good things with them. i assume the sound signature should be somewhat the same. or at least have some of the same atributes.
its cheaper to buy say the toxic cable,oyaide connector, silver solder and build a cable yourself. assuming you have the solder abilites and whatever else you may need to build your own cable...the toxic cable with oyaide connector could be made for around $150.00
the ''dream'' cable is expensive, but taking into consideration the time to build the cable,braid,shrink tube,solder,buy the solder, buy the cable buy the connector, wait for all of it to come in then construct it. imo convenience is worth the price. but obviously anyone who is DIY will say otherwise.
