lee730
- Jan 9, 2011
Its silver cable not silver plated. Don't waste your time with silver plated it won't work well. and its laminated so its covered not exposed.
How's the build on the silver cable? Is it hard to loop over the ear? Any pics of the cable?
Aya you making me take pictures now? Ok your wish is granted. I don't really have an issue with rapping them around my ear. I asked him to make it so they wrap around my ear as i think they normally hang down stock as opposed to over the ear. He bent them so that the work perfectly for my ears. No issues with microphonics over the ears. They also seem quite durable to me, but I also got a 3 year warranty from square trade just in case .
IE8s with Sflo2 and UHA4 Slimline amp/Fiio lod.
The IE8's stock cable has served me well. I think it's one of the strengths of this earphone.
If you're asking where to get the cables? I got mine from here
http://cgi.ebay.com/Advanced-Upgrade-Cable-SENNHEISER-IE8-Galaxy-silver-/120704302992?pt=LH_DefaultDomain_0&hash=item1c1a897f90
So its strength is also its weakness grasshopper.I haven't had any problems with the stock cable or connectors, but I'm intrigued by what you're saying. In what way do gold connectors out-perform nickel connectors, and silver wire improve upon the frequency response of whatever wire is used in the stock cable? Could you describe the differences that you hear between the two cables?
Anybody know where you can get the IE8 cable connectors from?
if you get custom cables from anywhere, get it from beat audio via custom-iem.com.
Their cable is without a doubt the best built and sonic quality and you can custom the plug. The cable is compatible with almost every type of removable cable iems out there including the ex1000
http://www.custom-iem.com/cables-c-123.html?zenid=77d2ddff483d93ad4c722703ce51d6bd
