shaddix
- Dec 24, 2007
Decided to keep the 595s and just buy some 650's so now I'll have two senns!!
Originally Posted by ccschua /img/forum/go_quote.gif HI CC report in. Too much capacitor is going to kill my appetite. Just buy another Volex 17604 for the ZERO DAC. Cost me about USD 13 delivered to door step. For a moment, I will just think about how to get the hump (is this the clipping we are talking about ) open up and make ZERO with bigger response. Just wonder when is PP reg arriving, and how's Alex doing with the reg too. |
Originally Posted by dacavalcante /img/forum/go_quote.gif Hi guys, I just decided to not use leads and instead of it plug zero direct to socket (if after caps mods it's still possible).... Would and acrilic top for the case, be just too ugly ? |
Originally Posted by AudioPhewl /img/forum/go_quote.gif Sennsay and Peete - cheers for your input ~Phewl. |
Originally Posted by Infoseeker /img/forum/go_quote.gif all these moddings, can a inexperienced solderer do these things? |
Originally Posted by Pricklely Peete /img/forum/go_quote.gif Hi AP, My pleasure,....funny thing about mods...they seem to evolve slightly as new ideas crop up. Never say never is a good mantra in this hobby That being said gluing the HDAM into the DIY CC cradle is a sound (pardon the pun) philosophy...just makes further mods kinda ....hard to complete.. Maybe the pins are exposed enough to allow access ? You could always trim down the sides (of the cradle) since the plastic offers no shielding benefit and just serves to hold the heat in...what do you think AP ? Would allow access while giving you a solid platform to place the HDAM anywhere you like without risk of shorting anything. Peete. |
Originally Posted by Pricklely Peete /img/forum/go_quote.gif Hi CC, Hi Diego, I dunno about that...beauty is in the eye of the beholder is it not ? A nice smoked acrylic top like the Keces DAC's have would look really cool IMHO !!!!. It would have to be custom made of course (DIY or ?) a big sheet of 1/4in thick stuff should do job for fairly cheap although I have no clue what this stuff actually costs. Peete. |
Originally Posted by shaddix /img/forum/go_quote.gif Decided to keep the 595s and just buy some 650's so now I'll have two senns!! |
Originally Posted by dario /img/forum/go_quote.gif I've just bought the 650 and selled the 595...I will wait for them the zero and hdam, what a revolution on my audio hardware... |
Originally Posted by dacavalcante /img/forum/go_quote.gif Yeah, maybe, but the problem is that zero isn't tall enough, so I would have to do a kind of box........ I guess I'll make things easier.... I'll just cut some holes for the HDAMs on Zero top case to fit them and cover it with an acrilic case...... maybe I can try to make it looks like HDAMs were inside a tube, like on tube amps.... but I really don't have all this skill..... |
Originally Posted by Penchum /img/forum/go_quote.gif Hi D, If you find a decent solution for this, that would be great! I did look into it some, but couldn't seem to find anything that required only limited fabrication skills. Do the wires really have you worried? So far, I can't tell if they are making a sonic difference, and they are allowing me to close up the case to protect the insides. I was also trying to preserve the stacking capabilities as well. Thoughts?? |
Originally Posted by dacavalcante /img/forum/go_quote.gif Hi Penchum, What do you call "stacking" ? You mean, to be able to put something else on the top of zero, like MKIII ? Well... I thought it would be a problem. A flat surface should be better.... I really don't have any problems with wires.... maybe it gets too much things inside of Zero and maybe it can get too hot to put 3 hdams on it........ Oh, and yes...... I'm a little worried about sonic differences... you know, we are willing to do all those mods on Zero, to a little wire mess a little bit with things.... Well, we also have to wait for the solution for feeding them.... maybe we do really need more space depending on the size of the power supply thing PP is working out..... When I have my HDAMs here I'll start up drawing some things.... I also want to know if there's a 12V line running on zero, where maybe a computer fan could be plugged.... |
