Penchum
- Oct 31, 2006
The clicking is normal, as long as it's not happening during a track you are playing.
The stock volume pot may be dirty. Use Deoxit or another tuner/electronics cleaner to flush out the volume pot.
I would recommend switching the headphone amp Opamps to the LT1364s, so you can listen that way too!
They are much better than the stock ones.
If you have no noise issues with the Denon's, I would leave out the impedance adapter.
When you first start listening to your music, set the volume purposefully lower than normal. In a matter of minutes, you'll notice it seems louder than when you started. At this point, increase the volume to a nice comfort level and you should be ok. If you think it is too loud, it is. Always try to caution on the side of less, is more.
Originally Posted by Shlonglor /img/forum/go_quote.gif Got my Zero. Woohoo! Plugged it in (though optical for now, till I get a proper digital RCA cable) and everything works well. A couple of issues: 1) It clicks randomly when on and playing. What the hey? A mechanical click that originates from within the box... I hope this doesn't foreshadow its impending death. 2) When no sound it playing, when I change the volume, I hear some noise/cracks. Is this normal? It seems to go away when it's playing. Other than that, pure bliss! I'm really enjoying it so far (the hour+ that it's been on). Zero + Denon AH-D2000 = A few other questions. I currently have the OPA627 which Lawrence installed for me in the DAC section and the default one in the amp section. 1) Should I bother with the default opamp at all or switch to the LT1364s I got as free samples when I gather the courage to open it up? 2) Is there a reason to shut it down when it's not being used (except for the super LEDs)? 3) I have a resistance increasing thingy that I got with my Super.Fis. Will using them with my Denons and increasing the power on the Zero provide any benefits? 4) How do I know when it's too loud and is going to damage my hearing permanently? |
