Originally Posted by jmooo /img/forum/go_quote.gif
It does work perfectly with supplies of +/-15V, read the datasheet carefully!
My apologies, I was going from memory. Could have sworn it was rated at +/-12v - I was so certain that I'd read this, I dropped the voltage feeding them in my diy headphone amp to +/-12v rather than +/-15v.
Damnit, they sounded really sweet at 15v too. All this time my ears have been crippled for no good reason!
Similar sounding opamps? The LT1358 is similar enough, and works perfectly in the DAC board. The THS4031 (dual is THS4032) is rather similar (and very good) too. |
Both sound similar to the LT1028. My recollection is that THS4032 appeared to give more detail on first impressions, but continued-listening revealed some 'wrong' sounds. It was a while ago, and I can't really put my finger on it...
Originally Posted by StratCat /img/forum/go_quote.gif
@AudioPhewl + ianp:
May I ask which vendor you ordered your Zero from, and how long it took for final delivery?
I'm in the UK, and I dealt with a lady in China who goes by the username '
snow48_6'. Took ~15 days to be delivered, but I think she sat on the order for the first 3/4 days going by her recent feedback - people who ordered 3 days after me received it on the same day.
How do you find the OPA2134 to sound, compared to the stock OPA2604?
Recently I tested the OPA2132 in an amp, and I found it to sound much better (there) than a much harder sounding LT1364. The LT1358, however, is better than both (there).
IMO, there is a difference, but it isn't huge. It's comparable to the difference between any other 2 good audio opamps. Biggest difference IMO is the midrange has stronger presentation, and the sound has a bigger feel to it.
My comments aren't particularly strong, I powered the Zero up and loved the sound. Whipped the lid off after a couple of hours use and swapped the opamps back and forth a few times - there was a difference, but I didn't use the OPA2604 long enough to give a detailed comparison.
Bloody IC sockets are a really tight fit on the legs of the IC. They have to be perfectly matched, or they'll bend over themselves very easily.
Originally Posted by Penchum /img/forum/go_quote.gif
Beware of ANDREA. If anyone with less than 25 posts starts telling you about the wonders of their Opamps, it is ANDREA under an assumed name. Just ignore him until the moderators can delete him and delete his posts.
Who, or what, is Andrea? Someone trying to plug their product?
Anyway, back on topic. I may just order some more LT1028s. I'll have to price up 6 of them(!), as well as the single-to-dual adapter boards.
~Phewl
