Penchum
- Oct 31, 2006
Ok, ummm, Lawrence is selling the OPA627AU's pre-soldered on an adapter. Drop him an email and check his price: lawrencechanbig@msn.com I think his price is better.
The LT1364's in the headphone amp are a big improvement over the stock Opamps. Very worth doing.
The Zero's amp vs MKV issue has been addressed before, but to summarize, the MKV is a much more refined headphone amp with better dynamics and purity of amplified signal. It should, it costs $300 compared to the Zero's whole unit cost of $139.
On the pre-amp issue, the button toggles it between line-level output and variable (volume knob) output. The majority use the line-level output and control their volume on the amp, or receiver, which is safe.
Originally Posted by Navyblue /img/forum/go_quote.gif Thanks again for your wonderful insight. I guess you ordered the dual OPA627 from Brown Dog together with the adapter? May I know if it is this one here? Two Pre-Mounted OPA627AU Op-amps on 020302 Adapter (p/n OPA627AU-020302S) - OPA627-020302S If so, it seems kinda pricey. How does the LT1364 compare to the above for the DAC section? Actually, it's not that I particularly like my headphone in my pre amp, it sounds really fine, but that's all I had before I build my speaker to headphone adapter. I think the adapter is a bit better than my pre amp. I think the sound is really fine, but I keep wondering if a dedicated amp (read LD Mk V) is better sounding. When LT1364 is used on the amplifier section, how does it compare to LD Mk I or LD Mk V. Is the difference subtle or obvious? Especially in the sound stage and instrument separation aspect. I have a question regarding the pre amp feature. When the right most button is pressed and there is no headphone present, does it's output toggle between full blast and volume knob regulated? If so I'd have to somehow secure that button so that I don't accidentally blast my head off. |
