catscratch
- Sep 29, 2004
By suffering in pain until the ears adjust. After about a week of using them straight the ears got used to it and it doesn't bother me quite as much anymore. Also, it helps to angle the eartips outwards slightly so they aren't quite as flush with your ear.
Though it has to be said that I only listen to about 1-2 hours at a time, and long-term comfort isn't as much of a priority.
Customs are still the way to go if you want comfort, unless you can find an IEM that sounds good with foam tips.
Originally Posted by Spyro /img/forum/go_quote.gif Great post Catscratch - Damn, how do you get beyond the (lack of) comfort issue with the clear flex tips? |
