tstarn06
Banned
- May 9, 2006
Explain what you did here. You took out the sound tube from the Comply? Not sure I understand. Is that the large Comply P, or the thin?
Originally Posted by Edward Ng /img/forum/go_quote.gif The problem for me with the modded triflanges is they are too dark; I think the bend in my ear canals is farther out, pinching them too shut. I can't cut the stalks any shorter because if I do, the body interferes with the largest flange and I can't get a seal. -Ed |
Originally Posted by BloodSugar00 /img/forum/go_quote.gif Nice idea Ed! It's been added to my list of tips/fits to try |
Originally Posted by tstarn06 /img/forum/go_quote.gif Tried your double Comply mod, but not much difference to me than using the thin Comply Ps straight up. A little more iso, but no change in the treble, still too bright for me. I immediately went back to the tri-flanges with the acoustic EQ and they sounded so much better. Guess it's a personal thing. I get absolutely no distortion using that EQ setting on my Touch. Weird. |
Originally Posted by tstarn06 /img/forum/go_quote.gif Just a quick note. I tried your "extender" mod, but instead of using a "ringlet" created from the core of the Shure yellow foamie, I simply used the discarded ringlets created when modding the tri-flange stalk. Just by cutting the stalk about 50 percent, I get the mod I want, and the piece that is chopped off is a perfect fit on the W3 stalk, so it creates the same effect without having to destroy a yellow foamie. Unfortunately, even with that mod and the T100 mediums on top of the rings, the W3s are still too bright for me. The tri-flange mod and EQ combo (see above) sounds so much better. In fact, I am so happy with that sound, I may not even spend the money on the UM56s, for fear the treble would be too bright and the money wasted. Why mess with success? I am gonna think it over. As you might have read a few posts up, DJ_JohnnyV also found the combo worked for him. Hit or miss, I guess. |
Originally Posted by tstarn06 /img/forum/go_quote.gif Try all the tips, of course, but be sure to try the acoustic EQ and tri-flange combo on your iPod. |
