[Review] iBasso D-Zero, with FiiO E7 Comparison
post-9251543
Post #61 of 102
pannomimi
Previously known as Boulder96
Thanks, hadn't experience that before as well as my J3. try use on low gain and use the volume control on the D zero. seriously the battery life is awesome haven't charge since the last week
Actually, I meant that when the d-zero is connected to the phone to be used as a DAC (USB Audio), it drains the battery of the phone very quickly. I am using the app "USB Audio Recorder Pro"
to play music
post-9254274
Post #62 of 102
Sachigatsu
oh that for sure it drain fast cause your're powering the dac using your phone's battery. anyway as in case you might not know, as for the dac it doesn't power using it's in-build battery. but it just weird that it drain that fast (listening to my d zero with w4r now.♪♪♪♪)
post-9254850
Post #63 of 102
pannomimi
That's weird. So the dac uses the phone's battery even if the charging switch is off?
I also pair my d-zero with my westone 4r too!
post-9257781
Post #64 of 102
Sachigatsu
as for that question usb dac are mainly use for pc (need more power). that may be the reason, correct me if i'm wrong.
 the soundstage even wider now
post-9637700
Post #65 of 102
clown1925
Hi everyone, this is off the topic... But i have bought my d zero without a warranty card but i bought it brand new... And i have only a seven days warranty... Would it be a problem for me? I mean the quality of the build of d zero
post-9640163
Post #66 of 102
pwyll
Based on my experience (which admittedly hasn't been too long) I don't think you'll need the warranty.  Use the heck out of it as much and as soon as you can, though, just to see if there are any "borderline" components...
post-9641111
Post #67 of 102
Syan25
I'm about to get one but please tell me I can get a USB otg cable online. Can't find a store that makes one!
post-9641834
Post #68 of 102
tomcourtenay
I think ibasso includes the otg cable with the d zero like they do with the d42
Enviado desde mi GT-I9505 usando Tapatalk 2
post-9641941
Post #69 of 102
clown1925
Is your d zero still workin fine? :) how long have you been using it?
post-9642935
Post #70 of 102
pwyll
I've been using it a little less than a month, but I'm the third owner.  It's very solid and well-built and feels like it will live longer than the Fiio E11 I got the same week  :)
post-9643213
Post #71 of 102
clown1925
That's nice to hear... I also got a fiio e11 and lend it to my friend... :) which one do you like between the two?
post-9645537
Post #72 of 102
pwyll
That's really hard to say.  I haven't had a chance to do a side-by-side comparison so I don't have a sound-based preference yet.  As far as hardware and design goes I'm old so I do prefer the on-off/volume knob of the E11 over the toggle and recessed wheel implementation on the D-Zero.  Otherwise, though, while the E11 doesn't seem "fragile" at all, the D-Zero feels more solid and robust and the smaller size doesn't seem to compromise on power at all.  Based on all that I tend to lean toward the D-Zero; add in the DAC and it's a fairly solid preference.
I really do like the knob on the E11 a lot, and a bit more time with them to compare the sound might change my mind, but if I had to give up one right now I would be keeping the D-Zero...
post-9646294
Post #73 of 102
Sachigatsu
hi using usb dac with a computer does the aux lineout bypass the amp ?
post-9646505
Post #74 of 102
Syan25
I'm about to buy the d-zero to work in conjunction with a HTC one phone...I've got my share se535 ready to test them. I bought an otg USB from Forza Audioworks in Poland. Looking forward to putting this ensemble together...
post-9666945
Post #75 of 102
Syan25
Just bought one
