[Review] iBasso D-Zero, with FiiO E7 Comparison
post-9668917
Post #76 of 102
yxpoh
Hi,
I am using Sansa Clip+. From what I heard, clip+ is not capable of producing a digital sound so they is totally no use to get a DAC like d-zero right?
so can i say that for my case, getting e11 for the stronger boost would be beneficial?
And i am currently using Hippo Box+, gift, is e11 better than what I have?
post-9669904
Post #77 of 102
Syan25
The D-zero is a head-amp too - for the price of $100 US - you are looking at a good purchase - just use a mini to mini interconnect...that's what I use if I am connecting to a device that doesn't have a USB or LOD connection...it still will sound much improved...
I just got my D-zero in the post today!!! Yeah - happy...time for burn in...
post-9669913
Post #78 of 102
yxpoh
Are you saying that by using the mini-usb to mini-usb I can get my music out to the d-zero directly?
Does it work that way? I rmb clip+ being incapable of doing that.
Or are you talking about just using the amp function of it?
Anyway, can anyone explain why some people would prefer the d42 to the d zero?
I am just a casual user who wish to get something concrete (and future proof?) for a budget price.
If the difference isn't that much, I don't see why do i need to get a d42 if you get what i mean.
post-9670107
Post #79 of 102
Syan25
If your sansa clip can't produce digital sound, you'll have to use the amp part of the d-zero with a mini to mini interconnect. Not a USB micro to mini cable. Both cables come in the d-zero box anyway....
post-9670117
Post #80 of 102
yxpoh
Oh, serious? I thought that I read somewhere that the connector for the sansa clip+ is purely for data transfer.
If that's that case, I can think about it.
but what do you think about a d42 over a d zero? Is the difference really worth the price difference as well?
post-9670124
Post #81 of 102
clown1925
I haven't tried the d42 but the dzero works so fine with me... I like it better than the e11, i don't know but i love it's soundstage and the cleansound it produces... :) but everyone has their own preference
post-9675800
Post #82 of 102
Syan25
Just burning mine in - but I say - sound on the dac is very clean and clear. The amp as a standalone has a slight warmth. Very pleased with this product. Testing with the Shure SE535s
post-9736834
Post #83 of 102
Syan25
I have to say I'm enjoying the amp slightly more than the DAC...perhaps its a shade warmer when using the amp only
post-9753268
Post #84 of 102
yxpoh
How about recommendation as an IEM amp, not headphone?
Would you still recommend it?
I am using a Sandisk Clip+ after all, and I am getting a quad driver CIEM..
I plan to decrease the number of choices and go ahead and try them when i get my CIEM and also after the exams...
post-9753871
Post #85 of 102
Syan25
I only use it with iems and it sounds great
post-9761542
Post #87 of 102
yxpoh
Oh.. Just remembered about this..
I am planning to use my Sandisk Clip+ but I remember that Sandisk, at high volumes, is almost a clean digital-like signal...
But D-zero uses an analog volume control which might have channel imbalance if it is too low (from what I have heard.)
Doesn't that mean that I might need to crank the volume up rather loud for the ears?
Or would the E7K be actually similar?
post-9766202
Post #88 of 102
Syan25
Sorry I don't know. I haven't had any issue with low volume on the d-zero.
post-9766283
Post #89 of 102
yxpoh
I see. So it comes down to trying it myself, i guess. Thanks for replying..
post-9773703
Post #90 of 102
pwyll
I agree with Syan25--I've run a Clip+ at low volume using the D-zero to amp it, and run the Clip+ at high volume using the D-zero to "limit" it and I haven't had any issues with low volume in either scenario.  Obviously the upper end is louder with the Clip feeding a higher volume, but even running the D-Zero at a low volume with the Clip+ feeding it at a low volume doesn't result in a channel imbalance that I can hear.
Works fantastic with my e260 Sansa, 5.5 Ipod Video and Ipod Mini as well...
