Sound Eq
- Nov 9, 2013
You, sir, are a genius!
I also love the RHA tips but only tried to get them over the wide bore of the 2.5s for a few seconds before giving up as I use the large tips which have a slightly longer core and thus are more malleable and more fiddly to get on. But thanks to you're post they're now and doing their thing.
u r welcome, whenever i buy an iem i spread out all the tips i have usually in sizes medium and large, and go through one song without using eqs, and try each and every tip i have, until i get to the point where i am completely satisfied
another think people can do is just take a silicon tip, and a comply tip, remove the plastic core of the comply, so you will have only comply foam
then roll over the comply on the shaft of your silicon tip
now you have a silicon tip from outside filled with comply foam inside
the above is just for experimenting and more tunning
then another thing u do with tips, is buy the radiance mold from ebay, flip the silicon inside out, fill the silicon with the molding radiance and stick in your ear to take shape of ear cannal, now you have a tip that is custom made for u. there is a video for that
see video
https://www.youtube.com/watch?v=ea8OXLvtI_A
