Just bought the used 2.0 first real IEM, so am wondering if anyone has the specs and any recommendations for amp or not etc...
Currently I have no DAP been using mainly Over Ears with lossless digital off laptop to my MHDT Havana to couple amp choices at the moment. Really looking forward to hearing these from all the posted comments they look like right up my alley
I use the crying C5 with mine. Excellent pairing. Fiio X3 OG was probably my favorite dap for them, love the hardware eq.
Also used Ray Samuel's intruder and another amp a friend lent me. All sounded very nice. Highly recommended to purchase an amp for them, big difference...
Also used a number of daps with them, all sounded pretty damn good.
I have a Mojo but havent paired them together yet, I could give it a go later if your interested. If not, I'm not in any rush.
How do the Rhapsodio RDB mk.IV compare to the ASG2.5? I read a review on the Rhap and apparently that has monster levels of sub/bass? Anyone tried them?
Thanks for the input. I currently have the supremely adjustable Garage 1217 starlight which is supposed to be able to dial it in for background silence. I also have a bottlehead crack which I doubt would be very good with IEM (I get tube hiss with Senn HD650 after approx 12 Oclock on the knob), I can turn down the output on foobar which should allow for more volume knob adjustment on the amp.
I really just want to get a good idea of SQ before I get into dap and portable amps. Also need to find out if I can stand wearing them (Comfort)
joespride I find then to be comfortable. As far as sound, with the bass port obviously it varies. The treble extension could be a little better. I eq them, mostly for treble. I find the mids wonderful, and the bass is wonderful.
2.0's arrived today have a couple ? 1 how do you determine polarity ? the cables are not clearly marked and appear as though they would mount either direction. @nd does anyone have contact information for Aurisonics ?
Listening to test tones in an attempt to gauge how low I can actually hear with these I find the left ear piece has a pretty bad vibration / buzz. Cant tell it with just music but it is definitely there at tones up and over 60hz
i recommended in the past using rha tips, so today i did some tip mod recommended in the sony z5 thread, get a medium comply foam tip and remove its plastic core from inside and slide it on the shaft of the rha tip
you will get great great isolation with incredible bass and highs
