Resistance of cables; pics, comments, and links
Jan 4, 2020 at 1:46 PM Post #241 of 407
After purchasing several upgrade cables, including the CEMA RX series, I have come to the conclusion that pure copper is my personal preference (because i prefer Nicehck C16-3 to the CEMA RX).
With that in mind there are a couple of examples due to go on sale soon on AE. I would like to purchase one of them and I was wondering if anyone owns either or both of these. The **** is occ and slightly more expensive and I think it's 2 pin connectors might be slightly better quality. Thank you in advance and apologies if i have posted this in the wrong thread!
£29.72 61%OFF | **** 8 Core 7N Single Crystal Copper Cable Taiwan Import 2.5/3.5/4.4mm Balanced Cable With MMCX Connector For KZAS10 ZS10 ZST
£25.78 73%OFF | OFHC 24 AWG 6N High Purity Copper Cable 2.5/3.5/4.4mm Balanced Cable With MMCX/2PIN/QDC For BL-03 BLON ZS10 PRO ZSX C12 BA5
Jan 4, 2020 at 11:55 PM Post #242 of 407
https://a.aliexpress.com/oTUBgtri
https://a.aliexpress.com/M001O7o8
You should take the links out as they point to one of the banned seller. Having said that i think the litz cable would be a better choice.. the 2nd one though the cable is a little stiff as it uses 24 AWG
Jan 5, 2020 at 3:51 AM Post #243 of 407
Oops. Sorry, didn't know there was such thing as a banned seller. Could you link me please to a list or names so I don't do that again. Thanks!
Edit: don't worry, just found reference. Slightly confused now since I have used that banned seller without problem.
Jan 5, 2020 at 8:40 AM Post #244 of 407
I have too but as long as we are on this site we gotta follow the rules here. It up to you if you want to continue using the seller... just no names or links or references on this site is what i am given to understand.
Jan 8, 2020 at 10:37 AM Post #245 of 407
Having ordered the CEMA electro acousti RX series, I would like to order one of his pure copper cables. There are two in my price range....the 4 core RS series or the 4 core up-occ CS series which is twice the price. Hakuzen says the cheaper cable isn't very strong. My question is whether CS is really worth twice the price of RS? I will be pairing with Moondrop Kxxs. Thanks.
Jan 8, 2020 at 2:15 PM Post #246 of 407
I have RX series not bad and other higher price one
Jan 10, 2020 at 8:16 AM Post #248 of 407
May someone please remember me what means "Ag" and "Au".
I think "Ag" is silver but what about "Au" ?
Jan 17, 2020 at 6:16 PM Post #250 of 407
Argentum and Aurum.. thats why in the bond movie Goldfinger the epic best bond villain ever was named Aurik Goldfinger (Gerd Fröbe was the best! and funny i didnt realize that as a kid that his name has something to do with gold :wink:)
Jan 31, 2020 at 1:19 PM Post #251 of 407
Hi all,
I own a trn v90 and I'm looking to buy a upgrade cable. I don't like the earhooks from the original cable.
I'm looking for a all black cable, 2 pin 0.78mm, no cable slider, and light weight.
I found this one from Nicehck:
https://a.aliexpress.com/_U0bjY
Would this be a nice cable? I have looked at the specs and can't find it it's a 2 pin 0.75mm or 0.78mm. my trn v90 connector holes are not that tight so I want a 0.78 2pin
Jan 31, 2020 at 8:17 PM Post #252 of 407
Hi all,
i think yes, it is a decent cable (050 in my list). if you get it at main nicehck shop, the price is even a bit lower (https://www.aliexpress.com/item/32889396437.html).
you can also check cable 063 (16 cores) or even cable 061 (8 cores like 050, different jack, worse conductivity), and 053 (black color version).
all them use 0.78mm pins. anyway, i've not found much difference between 0.75 and 0.78mm, except in a very few cases.
Feb 20, 2020 at 12:28 PM Post #253 of 407
I was looking at purchasing the isn cable, either c16/h16/c4/s4, for my audiosense t800, any idea which would pair best?
Feb 20, 2020 at 12:52 PM Post #254 of 407
With S4 T800 are great. Definition and no sibilance at all
Feb 20, 2020 at 12:54 PM Post #255 of 407
Is there supposed to be an actual difference between the s4 and s16 besides gauge and core count?
